I have read all feature classes and their associated geodata like Point,polyline,polygon data. API is taking too much time in reading these data.
My code is as follow:
Table testtable = geodatabase.OpenTable("\\sw_Manhole");
geoshape.Items = new List<ImpexItem>();
geoshape.LayerName = child;
bool checkFields = false;
int fieldCount = table.FieldInformation.Count;
foreach (Row row in table.Search("*", "", RowInstance.Recycle)) // reading coordinates
ImpexItem layerItem = new ImpexItem();
layerItem.PartList = new List<ImpexPart>();
ImpexPart itemParts = new ImpexPart();
itemParts.Coordinates = new List<PointD>();
if (row.GetGeometry().shapeType.ToString() == "Point")
PointShapeBuffer geometry = row.GetGeometry();
Esri.FileGDB.Point point = geometry.point;
PointD itemPoints = new PointD();
itemPoints.X = point.x;
itemPoints.Y = point.y;
itemParts.Coordinates.Add(itemPoints);
else
try
MultiPointShapeBuffer geometry = row.GetGeometry(); // if geometry type is polygon/polyline
Esri.FileGDB.Point[] point = geometry.Points;
for (int numpoints = 0; numpoints < point.Length; numpoints++)
itemPoints.X = point[numpoints].x;
itemPoints.Y = point[numpoints].y;
catch (Exception e)
Console.WriteLine("MultiPoint Exception" + e.Message);
layerItem.PartList.Add(itemParts);
geoshape.Items.Add(layerItem); // one layer data
}for loop will run 300 times and its taking more then 4 minutes for reading this simple data.
Message was edited by: Vince Angelo (Formatted for legibility)
You've left a great deal out of this post, making it almost impossible to assist:
In the future, please format code using the "Use advanced editor" option, selecting the code block, and choosing the ">>" icon to specify formatting with "Syntax Highlighting" or "C#" (or whatever is appropriate). It would also help to explicitly state you are using the 1.4 API with C# language and whatever IDE you are using.
- V
Using a C++ app I had already created, I fetched every row of "\\sw_Manhole", and it took 7.3 MILLISECONDS to read 302 rows with 33 fields (OpenTable took 3.2ms, so the actual average read duration was 12.4 microseconds per feature). Each shape had one vertex (they're points, after all).
./fgdbtimer2 ../WS_Data.gdb "\sw_Manhole" SHAPE Field 1: OBJECTID OID Field 2: ASSET_ID NSTRING Field 3: INSTALL_DATE DATE Field 4: RIM_ELEVATION FLOAT64 Field 5: DEPTH FLOAT64 Field 6: DIAMETER FLOAT64 Field 7: COVER_TYPE NSTRING Field 8: VENT_TYPE NSTRING Field 9: DROP_STRUCTURE INT16 Field 10: CONTRACTNUM NSTRING Field 11: ASSET_STATUS NSTRING Field 12: OWNERSHIP NSTRING Field 13: MANAGEDBY NSTRING Field 14: UPDATETXID INT32 Field 15: LASTEDIT DATE Field 16: WS_STREET NSTRING Field 17: WS_CROSS_STREET NSTRING Field 18: WS_MANUFACTURER NSTRING Field 19: WS_PROJECT_NAME NSTRING Field 20: WS_PROJECT_PHASE NSTRING Field 21: WS_ASSUMPTION_AREA NSTRING Field 22: WS_GPN NSTRING Field 23: WS_DEVELOPER NSTRING Field 24: WS_CONSULTANT NSTRING Field 25: WS_FEATURE_CREATE DATE Field 26: WS_FEATURE_EDIT DATE Field 27: WS_LAST_EDITOR NSTRING Field 28: RJB_FLOW_TYPE INT16 Field 29: created_user NSTRING Field 30: created_date DATE Field 31: last_edited_user NSTRING Field 32: last_edited_date DATE Field 33: Shape SHAPE mode: SHAPE reads: 303 v/f: 1 ms_desc: 0.153 ms_open: 3.27 ColA: 3.423 ms_read: 3.769 ms_get: 0.122 total: 7.314
Your application is sub-optimal for performance evaluation because of multiple GetGeometry invocations, but there's nothing obvious as to why my app should run nearly 33 thousand times faster. I recommend you:
You can then report back on the timing for each function call.
- V
PS: MultiPointShapeBuffer is for multipoint shapes -- Lines and Polygons use MultiPartShapeBuffer
Maybe the problem is in
this feature works slow enough when you catch exceptions.
I tried same code - it works well. Check console output.
