ESRI.FileGDBAPI.dll and VS redist
3615
07-25-2016 11:41 AM
GlennFernandez
Hi, I reference the ESRI.FileGDBAPI.dll and the other two dlls (FileGDB version 1.4) ins VS 2015 project.
Build the project and deployed in a target machine that has no VS2015 installed. When exe was run got an error that says it can load the ESRI.FileGDBAPi.dll.  Question is what version of VC++ redistributable do I need to have in the deployment machine. From previous posting, I saw that the API needs VS 2008 redist, is this still the case even if I built the project/exe in VS2015?
Thanks a lot.
LanceShipman
We don't support VS2015 with version 1.4 of the file geodatabase API. We will be supporting VS2015 in the 1.5 version of the API sometime before the end of 2016.
You could try using the redistributable for the version of the API you built with (VS2013?).
JanKleemann
Hi, is there any news/ETA when version 1.5 with VS2015 support will arrive?
LanceShipman
Our current target is to release the File Geodatabase API 1.5 by the end of January 2017.
JanKleemann
Great! Thank you very much.
