DATE queries crash
5736
01-06-2014 12:32 PM
PaulAustin
A query with a date such as the following crash applications. Mac OS X Mavericks. Haven't tested on windows.
SELECT OBJECTID FROM TABLE WHERE DATE_FIELD < date '2013-09-01'
C  [libsystem_c.dylib+0x5b6dd]  strtok_r+0x66
C  [libfgdbunixrtl.dylib+0x5d8c]  _Z13GetLocaleInfojjPwi+0x50c
C  [libfgdbunixrtl.dylib+0x1fa31]  _Z14VarDateFromStrPwjjPd+0xe1
C  [libfgdbunixrtl.dylib+0x26190]  _Z19VariantChangeTypeExP10tagVARIANTS0_jtt+0x3130
C  [libFileGDBAPI.dylib+0x86f67]  _ZN6SqlLex7GetDateEPPwRiRdS0_+0x237
C  [libFileGDBAPI.dylib+0x89cc6]  _ZN8SqlParse12ParseLiteralEPPwRiRP7SqlNodeS0_+0x11c
C  [libFileGDBAPI.dylib+0x8a7d8]  _ZN8SqlParse12ParsePrimaryEPPwRiRP7SqlNodeS0_b+0x3a
C  [libFileGDBAPI.dylib+0x8bfb8]  _ZN8SqlParse11ParseFactorEPPwRiRP7SqlNodeS0_b+0x1ee
C  [libFileGDBAPI.dylib+0x8c0fe]  _ZN8SqlParse9ParseTermEPPwRiRP7SqlNodeS0_b+0x4a
C  [libFileGDBAPI.dylib+0x8aa26]  _ZN8SqlParse15ParseExpressionEPPwRiRP7SqlNodeS0_b+0x4a
C  [libFileGDBAPI.dylib+0x8d0e8]  _ZN8SqlParse14ParsePredicateEPPwRiRP7SqlNodeS0_+0x788
C  [libFileGDBAPI.dylib+0x8db3d]  _ZN8SqlParse19ParseBooleanPrimaryEPPwRiRP7SqlNodeS0_+0xb7
C  [libFileGDBAPI.dylib+0x8dd0b]  _ZN8SqlParse18ParseBooleanFactorEPPwRiRP7SqlNodeS0_+0x69
C  [libFileGDBAPI.dylib+0x8de0a]  _ZN8SqlParse16ParseBooleanTermEPPwRiRP7SqlNodeS0_+0x46
C  [libFileGDBAPI.dylib+0x8dbaa]  _ZN8SqlParse20ParseSearchConditionEPPwRiRP7SqlNodeS0_+0x46
C  [libFileGDBAPI.dylib+0x8dae6]  _ZN8SqlParse19ParseBooleanPrimaryEPPwRiRP7SqlNodeS0_+0x60
C  [libFileGDBAPI.dylib+0x8df21]  _ZN8SqlParse10ParseWhereEPPwRiRP12SqlNodeWhereS0_+0x1f
C  [libFileGDBAPI.dylib+0x8af1b]  _ZN8SqlParse11ParseSelectEPPwRiRP12SqlStatementS0_+0x10d
C  [libFileGDBAPI.dylib+0x8f064]  _ZN8SqlParse14ParseStatementEPPwRiRP12SqlStatementS0_+0x34
C  [libFileGDBAPI.dylib+0x8f19d]  _ZN8SqlParse17ParseSqlStatementERK6StringPP12SqlStatement+0x53
C  [libFileGDBAPI.dylib+0xf1c5b]  _ZN10SqlCommand14CreateInstanceEP7CatalogRK6StringPPS_+0x3b
C  [libFileGDBAPI.dylib+0x1610]  _ZNK10FileGDBAPI11Geodatabase10ExecuteSQLERKSbIwSt11char_traitsIwESaIwEEbRNS_8EnumRowsE+0x5c
C  [libEsriFileGdbJni-x86_64-macosx.dylib+0x2b76b]  _ZL28FileGDBAPI_Geodatabase_queryPN10FileGDBAPI11GeodatabaseERKSbIwSt11char_traitsIwESaIwEEb+0x6b
C
LanceShipman
The query works as expected on Windows. I'll enter a bug and we will verify that it is working with Mac OS X Mavericks in the next release.
RavenKopelman
Hi Lance, is this still under investigation?  I'm happy to provide more details if it helps.
RavenKopelman
As of 1.4 the crash still appears on Linux (Ubuntu 14.04).  Here is a simple repro application:
#include <FileGDBAPI.h>
int main(int, char**)
  FileGDBAPI::Geodatabase geodb;
  fgdbError result = FileGDBAPI::OpenGeodatabase(L"seed.gdb", geodb);
  if (FAILED(result))
      printf("Error: FileGDBAPI::OpenGeodatabase(L\"seed.gdb\", geodb)\n");
      return 1;
  FileGDBAPI::Table currTable;
  result = geodb.OpenTable(L"\\update_by_match_columns", currTable);
  if (FAILED(result))
      printf("Error: geodb.OpenTable(L\"\\\\update_by_match_columns\", currTable)\n");
      return 1;
  FileGDBAPI::EnumRows currRows;
  result = currTable.Search(L"*", L"date_attr = DATE '2015-01-01 00:00:00'", true, currRows);
  return 0;
#0 strtok () at ../sysdeps/x86_64/strtok.S:186
#1 0x00007fa703aa0581 in GetLocaleInfo(unsigned int, unsigned int, wchar_t*, int) () from /git/fme-1/install/fmecore/libfgdbunixrtl.so
#2 0x00007fa703ad0450 in VarDateFromStr(wchar_t*, unsigned int, unsigned int, double*) () from /git/fme-1/install/fmecore/libfgdbunixrtl.so
#3 0x00007fa703ad54d4 in VariantChangeTypeEx(tagVARIANT*, tagVARIANT*, unsigned int, unsigned short, unsigned short) ()
#4 0x00007fa704a37bbd in SqlLex::GetDatetime(wchar_t**, int&, double&, wchar_t*, esriSQLDatetimeType&) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#5 0x00007fa704a38126 in SqlParse::ParseLiteral(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#6 0x00007fa704a3b740 in SqlParse::ParsePrimary(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#7 0x00007fa704a3ba2d in SqlParse::ParseFactor(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#8 0x00007fa704a3bd7f in SqlParse::ParseTerm(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#9 0x00007fa704a3c0ff in SqlParse::ParseExpression(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#10 0x00007fa704a3e69d in SqlParse::ParsePredicate(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#11 0x00007fa704a3f6f9 in SqlParse::ParseBooleanPrimary(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#12 0x00007fa704a3f7e7 in SqlParse::ParseBooleanFactor(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#13 0x00007fa704a3f91f in SqlParse::ParseBooleanTerm(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#14 0x00007fa704a3faa1 in SqlParse::ParseSearchCondition(wchar_t**, int&, SqlNode*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#15 0x00007fa704a3fbec in SqlParse::ParseWhere(wchar_t**, int&, SqlNodeWhere*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#16 0x00007fa704a3da9e in SqlParse::ParseSelect(wchar_t**, int&, SqlStatement*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#17 0x00007fa704a40461 in SqlParse::ParseStatement(wchar_t**, int&, SqlStatement*&, wchar_t*) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#18 0x00007fa704a40602 in SqlParse::ParseSqlStatement(String const&, SqlStatement**) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#19 0x00007fa704af9a67 in SqlCommand::CreateInstance(Catalog*, String const&, SqlCommand**) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#20 0x00007fa704988442 in FileGDBAPI::Geodatabase::ExecuteSQL(std::basic_string wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&, bool, FileGDBAPI::EnumRows&) const () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#21 0x00007fa704998669 in FileGDBAPI::Table::Search(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&, std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&, bool, FileGDBAPI::EnumRows&) () from /git/fme-1/install/fmecore/libFileGDBAPI.so
#22 0x0000000000400cf0 in main ()
  at ../../formats/filegdb/repro/strtok_crash.cpp:23
