CREATE VIEW ?
2531
02-27-2012 04:58 AM
OlivierOlivier
Does a fgdb could support "CREATE VIEW" ? I tried
Dim sqlStatement As String ="CREATE VIEW TEST (V1,V2) AS SELECT field1,field2 FROM my_table"  geodatabase__1.ExecuteSQL(sqlStatement)
goto no error, no result, no change inside the geodatabase
Thanks for any answer
Olivier
DavidSousa
At the present time, the File Geodatabase does not support the concept of a view.  It has been discussed, and could be added without a huge amount of difficulty.  However, as of yet, there has been no decision to go forward with this idea.
DavidSousa
OlivierOlivier
Thanks for your answer, David.
