Cannot close a GeoDatabase after creating it.
4792
6
02-21-2013 11:57 PM
MaoEdgar
I created a GeoDatabase and added a table and added a field and I cannot close it. Can anyone help on this?
Attached is the sample, the version of dll is 1.2.0.136.
Edgar
VinceAngelo
Esri Esteemed Contributor
Why are you opening the same geodatabase twice?
The documentation indicates that FileGDBAPI::Geodatabase::GetChildDatasets would
be used to get the list of tables.
- V
VinceAngelo
Is there a particular reason you're not using the 1.3 API release?  Given a new
product with a standalone library, I can't see any.
If your application is 10 lines long, then you are drastically reducing the number
of folks who will look at it by posting as a zip file (as opposed to including it in
a CODE block within the post).
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Esri.FileGDB;
using System.IO;
namespace ConsoleApplication2
    class Program
        static void Main(string[] args)
            //1.2.0.136
            Geodatabase.Create("a.gdb");
            Geodatabase geodatabase = Geodatabase.Open("a.gdb");
            string template = File.ReadAllText("../../template.xml");
            string tableDef = template.Replace("%Name%", "myTable").Replace("%ShapeType%", "esriGeometryPoint");
            Table table = geodatabase.CreateTable(tableDef);
            string fieldTemplate = File.ReadAllText("../../fieldTemplate.xml");
            table.AddField(fieldTemplate.Replace("%Name%", "pointField"));
            table.Close();
            //stop here
            geodatabase.Close();
If you don't ever test error results, any number of bad things can happen.
Have you tried eliminating the AddField or AddField and CreateTable steps?
I don't see a Close request on Table in the C++ documentation.
- V
MaoEdgar
Thanks for your answer, I comment the Geodatabase.Create("a.gdb") or I change it to Geodatabase.Create("a.gdb").Close() and it works fine, however, there seems to be a bug in Opening the database? Here are the secnerios,
var b = Geodatabase.Open("a.gdb");
var a = Geodatabase.Open("a.gdb");
//stops here
a.Close();
b.Close();
//works fine.
b.Close();
a.Close();
Is the Close method supposed to be called in a specified sequence?
MaoEdgar
One more question, is there any way to get the table names from a database? It seems that I must specify a table name before querying it.
Edgar
VinceAngelo
- V
MaoEdgar
Thanks for the answer about my last question, but can't I open the same database twice? It's a static method I thought I could do that but failed on the sequence.
Regards,
Edgar
VinceAngelo
You *shouldn't* open anything more than once, especially when it provides
multiple concurrent table handles as part of a single open.  But the fact that
doing so exposes a bug in the Linux implementation was already discovered
earlier this month.
- V
