Sidebar Custom - Auto Expand when using "Add to table" or "View in Table"
1232
11
02-02-2026 03:42 PM
Brian_McLeer
MVP Regular Contributor
4 11 1,232
https://github.com/brianmcleer/sidebar-custom-widget
A customized version of Esri's Sidebar widget for ArcGIS Experience Builder. It keeps everything the stock Sidebar does and adds automatic expansion so a collapsed sidebar opens itself when a table is shown, which keeps the Table widget visible inside the sidebar instead of hidden behind a collapsed panel.
Features
  • Auto-expand on table open. When a collapsed sidebar contains a Table widget and a user runs "Add to table" or "View in table", the sidebar expands automatically so the table is visible.
  • Auto-expand for widget controllers. A collapsed sidebar also expands when a widget inside a Widget Controller is opened, so the controller content is not stuck behind a collapsed panel.
  • Everything from the stock Sidebar widget: two configurable panels (FIRST and SECOND), fixed layouts, the toggle button with its configurable colors and border, and the toggle and open message actions.
Changelog:
6/26/26:
  • Auto-resize for tools and tables. The sidebar can widen to a size you set while a tool or table is open, then go back to its normal width when it closes. It respects a manual resize, so it won't override a width you set yourself.
  • Peek on hover. Hovering the collapsed edge briefly reveals the sidebar, and it re-collapses when you move away. Good for a quick glance without fully opening it.
  • Update badge. A small dot shows on the toggle button when the collapsed content changes while the sidebar is closed, so users notice new results. It clears once the sidebar is opened.
  • Pin and close panel header. An optional header bar on the panel adds a pin button that keeps the sidebar open and holds off the auto-collapse behaviors until you unpin, plus a close button.
  • Published expand/collapse message. The sidebar can send an "expanded" or "collapsed" message that other widgets can react to through a standard message action.
  • URL deep-linking. The open or collapsed state can be saved in the URL and restored on load, so a shared or bookmarked link opens in the same state.
  • Everything new is off by default and set in the widget's Behavior settings, so existing apps don't change until you turn something on.
2/23/26:
  • Widget now supports auto expansion for widget controller or view/add in table.
  • Have collapsed sidebars expand when using "Add to table" or "View in table"" to show Table widget within sidebar. Also supports auto-expansion for widget controllers.
(view in My Videos)
Comes from an idea and great solution by @JeffreyThompson2 at The Automatically Opening Attribute Table.
11 Comments
ElisabethFenn
This is a great improvement! As I'm testing it out I'm seeing an issue that I don't have with the original sidebar app. When I go to add a layer to the table, it gives me the table option twice. I've confirmed this is the same table listed twice and not a second table in the app. Have you seen this happen?
Brian_McLeer
Thank you @ElisabethFenn. I have seen the double table you are seeing occasionally, but it was before I created the sidebar custom. Are you using the out of the box map layers widget or a custom one? I have a modified custom one, which is why I though the double table option was an isolated issue.
Brian_McLeer
@ElisabethFenn, I think this may be a bug. I created a testing application in DE 1.19 using all out of the box tools. The issue does not appear in DE, but it does on a deployed application. I may have to create a ticket with Esri support.
DE:
Deployed testing application:
ElisabethFenn
@Brian_McLeer Interesting. I am using the out of the box map layers widget.
Yesterday I hadn't published yet and was just using the preview function in exb dev 1.19 and was seeing the double table issue.
Today I confirmed the double table is still there in preview, then I deployed my test app and I do not see the double table issue with the deployed version.
That's the opposite of what you're seeing though.
Brian_McLeer
@ElisabethFenn interesting we are having the same issue but in opposite scenarios. I will keep you updated on results of my support case.
Brian_McLeer
@ElisabethFenn Esri Support was able to replicate the issue on their end using DE 1.19 with no custom widgets. It may be logged as a bug pending more testing, and then a bug may be posted on Esri's bug site.
Brian_McLeer
@ElisabethFenn this has been logged as BUG-000182651. I think you can create a support ticket and ask to have your account associated with the bug to get status updates and see it from the My Esri support site.
Brian_McLeer
Update on 2/23/26:
Brian_McLeer
Brian_McLeer
@ElisabethFenn I received a notification today about BUG-000182651 has been addressed this morning. It looks like the duplicate add to table bug may be fixed when DE 1.21 is released later this month.
ElisabethFenn
@Brian_McLeer Great news!
Contributors
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
