Send Data Source from Custom Widget to Table Widget
2468
05-24-2024 04:07 PM
Esprit3
So, I have a custom widget, where the user can select a layer from a map. From there he can choose a field, an operator and input a value. This creates a query for the layer and I set Field Out to "*". So basically, I am retrieving all items that match the query with all their fields. I would like to send this response, all the items with all their fields with respective values to the table widget.
widget.tsx:
try {
      const result = await layer.queryFeatures(query);
      const resultData = result.features.map((feature) => ({
        attributes: feature.attributes,
        geometry: feature.geometry,
      console.log("result=", result);
      props.dispatch(appActions.widgetStatePropChange("attribute_table", "queryResult", resultData));
      highlightAndZoomToFeatures(result.features);
      const dataSourceManager = DataSourceManager.getInstance();
      const outputDsId = `${props.id}-output`;
      const outputDataSource = dataSourceManager.getDataSource(outputDsId) as FeatureLayerDataSource;
      if (outputDataSource) {
        const dataRecords = result.features.map(feature => outputDataSource.buildRecord(feature));
        const fields = result.fields.reduce((acc, field) => {
          acc[field.name] = {
            jimuName: field.name,
            alias: field.alias,
            type: field.type,
            esriType: field.esriType
          return acc;
        const updatedSchema = Immutable({
          idField: "__OBJECTID",
          fields
        outputDataSource.setSchema(updatedSchema);
        outputDataSource.setSourceRecords(dataRecords);
        outputDataSource.setStatus(DataSourceStatus.Unloaded);
        outputDataSource.setCountStatus(DataSourceStatus.Unloaded);
        const dataActionManager = DataActionManager.getInstance();
        const actions = dataActionManager.getActions();
        const viewInTableAction = actions.find(action => action.id === 'widget_6-viewInTable');
        if (viewInTableAction) {
          const dataRecordSet: DataRecordSet = {
            dataSource: outputDataSource,
            records: dataRecords,
          viewInTableAction.onExecute([dataRecordSet], DataLevel.Records, props.id);
        } else {
          console.error("View in Table action not found");
      } else {
        console.error("Output data source not found");
    } catch (error) {
      console.error("Error executing query:", error);
setting.tsx:
/* eslint-disable */
import { React } from 'jimu-core';
import { AllWidgetSettingProps } from 'jimu-for-builder';
import { MapWidgetSelector } from 'jimu-ui/advanced/setting-components';
import { DataSourceJson, DataSourceTypes } from 'jimu-core';
const { useEffect } = React;
const Setting = (props: AllWidgetSettingProps<any>) => {
  const onMapWidgetSelected = (useMapWidgetIds: string[]) => {
    props.onSettingChange({
      useMapWidgetIds: useMapWidgetIds
  useEffect(() => {
    const outputDsJsons: DataSourceJson[] = [{
      type: DataSourceTypes.FeatureLayer,
      label: "Query Result Layer",
      originDataSources: [],
      isDataInDataSourceInstance: true
      useDataSources: []
    }, outputDsJsons);
  return (
    <div className="widget-setting-demo">
      <MapWidgetSelector useMapWidgetIds={props.useMapWidgetIds} onSelect={onMapWidgetSelected} />
    </div>
export default Setting;
With this, in the table widget I can select Query Result Layer output as data action. However, whenever I try to execute the query I get this error:
I would appreciate any kind of help. Please let me know if you need more info... Thanks!
Note: I tested this with a custom table, everything works as expected.
JacobAndrews
Did you ever happen to find out an answer to this? I am trying to solve a similar issue.
JeffreyThompson2
MVP Frequent Contributor
I have seen that error before trying to create a FeatureLayer on the client-side. FeatureLayers must have either the url property or the source property with any array of Graphic objects.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#source
GIS Developer
City of Arlington, Texas
ericsamson_tract
Any ideas on this? I am trying to send a featurelayer to the attribute table programmatically. Somewhat different from what you are doing but along the same lines.
UmutUcok
Instead of passing programatically, I believe right way to do is to configure output data source then select it in Table widget.
