Introduction
https://github.com/brianmcleer/rightclick-widget
The Right Click widget adds contextual map tools to ArcGIS Experience Builder. When a user right-clicks on the map, a menu appears offering a set of configurable actions. This provides access to functions like zoom, measurement, coordinate copying, marker plotting, text placement, and reverse geocoding.
End User Interaction
Once deployed, users can right-click anywhere on the map to open a context menu. Depending on the configuration, the following actions may be available:
Navigation Actions:
- Zoom In / Zoom Out: Adjusts the zoom level at the click location
- Center Here: Pans the map to center on the clicked point
Coordinate Actions:
- Copy Coordinates: Copies the location to the clipboard using the configured coordinate system
- Plot Coordinates: Places numbered coordinate markers with configurable styling and coordinate labels
- Plot Marker: Places simple markers with customizable appearance
Graphics Actions:
- Add Text: Places custom text graphics on the map with configurable font properties
- Clear All Graphics: Removes all placed markers and text (displays count when graphics are present)
External Services:
- Open in Google Street View: Opens the location in Google Street View using projected coordinates
- Open in Pictometry: Opens the location in Pictometry aerial imagery viewer using projected coordinates
Measurement Tools:
- Measure Distance / Measure Area: Opens measurement tools with the following features:
- Automatic segment and total labeling for distance measurements
- Filtered unit options
- Single or dual unit display options
- Close button for tool termination
Information Services:
- What's Here?: Performs location identification using:
- Reverse geocoding via configured locator service for address lookup
- Feature layer queries against configured ArcGIS Feature Services
- Popup display showing results from both geocoding and feature layer queries
The context menu adapts based on administrator settings. Tools close automatically after use or on map interaction.
Measurement Tools
The measurement functionality includes the following specifications:
Available Units
- Distance measurements: Feet, Yards, Miles, Meters, Kilometers
- Area measurements: Square Feet, Square Yards, Square Miles, Square Meters, Square Kilometers, Acres
Unit Display Options
- Single Unit Only: Displays measurements in the selected default unit
- Show Both Units: Displays measurements in both the primary unit and its converted equivalent (e.g., "150.00 feet (45.72 meters)")
Interface Elements
- Distance measurement tool includes a Close button
- Area measurement tool includes a Close button
- Default "New measurement" buttons are removed
Coordinate and Marker Plotting
The widget provides two types of marker placement:
Coordinate Markers:
- Numbered sequentially starting from 1
- Display configurable coordinate information in popups
- Support multiple coordinate systems (map native, WGS84, custom WKID)
- Optional coordinate labels displayed on map
- Configurable marker styles, colors, outlines, and positioning
- Support decimal degrees or degrees/minutes/seconds format for lat/lon
Simple Markers:
- Basic point markers without numbering
- Fully customizable appearance including style, size, color, outline, rotation, and offsets
- Support transparency settings
Text Graphics:
- Custom text placement at clicked locations
- Configurable font family, size, weight, and color
- Optional text outlines (halo) and backgrounds
- Persistent during browser session
Developer Configuration
Map Widget Selection
- Connects the Right Click widget to map widgets in the application
- Enables right-click functionality on selected maps
Enabled Actions
Each action can be individually toggled:
- Zoom In
- Zoom Out
- Center Here
- Copy Coordinates
- Plot Coordinates
- Plot Marker
- Add Text
- Measure Distance
- Measure Area
- What's Here?
Coordinate System Settings
The format for copied coordinates can be configured:
- Use the current map's coordinate system
- Use WGS84 (latitude/longitude)
Plot Coordinates Settings
Comprehensive marker configuration options:
- Coordinate System: Map native, WGS84, or custom WKID
- Format Options: Decimal degrees or degrees/minutes/seconds for lat/lon
- Marker Style: Circle, Square, Cross, X, Diamond, Triangle, Pin
- Visual Properties: Size, color, outline color/width, opacity, rotation angle
- Positioning: X/Y offset controls for precise placement
- Text Settings: Number text size and color
- Labels: Optional coordinate labels with customizable offset, size, and color
- Popup Content: Toggle coordinate display in marker popups
Simple Marker Settings
Independent styling controls for basic markers:
- Style Options: Circle, Square, Cross, X, Diamond, Triangle, Pin
- Appearance: Size, color, outline properties, opacity
- Positioning: Rotation angle and X/Y offsets
Text Settings
Font and display configuration for text graphics:
- Typography: Font family, size, weight (normal/bold)
- Colors: Text color and outline (halo) color
- Effects: Outline size, optional background color
- Background: Transparent or colored background options
Reverse Geocoding Configuration
- Reverse geocoding service URL field for "What's Here?" functionality
- Optional WKID setting for coordinate projection
- Feature layer configuration for "What's Here?" queries:
- Add multiple ArcGIS Feature Service layers
- Select specific fields to display from each layer
- Configure search radius and maximum results per layer
- Set spatial relationship parameters for queries
Feature Layer Configuration
Advanced settings for "What's Here?" functionality:
- Layer Management: Add/remove feature layers with custom names
- Field Selection: Choose specific fields to display from each service
- Service Integration: Automatic field loading from Feature Service URLs
- Display Options: Configure field aliases and grouping
Popup Display Settings
Customization options for information popups:
- Layout: Popup width and maximum height settings
- Content Organization: Show/hide layer names, group by layer option
- Field Display: Use field aliases or raw field names
- Styling: Responsive design with scrolling for large content
Measurement Settings
- Default Units: Select from Feet, Yards, Miles, Meters, or Kilometers
- Unit Display: Choose between single unit display or dual unit display with conversions
External Service URLs
- Pictometry Integration: Configure Pictometry service URL with coordinate parameters
- Geocoding Services: Set reverse geocoding service endpoints
Widget Placement
The widget does not display interface components and operates in the background. Recommended configuration:
- Set widget size to 0×0 pixels
- Place in unused corner of the layout
- Use "Send to back" option in layout settings
- Keep widget visible and active
- Recommended for desktop only, not for tablet/phone viewers
Technical Notes
- Unit dropdown options are filtered to show only the specified available units
- Invalid unit selections are blocked and revert to default units
- Console logging is limited to warnings and errors
- Widget includes cleanup procedures for memory management
- Graphics persist during browser session but are cleared on page refresh
- Coordinate projections support multiple spatial reference systems
- Field metadata is automatically loaded from configured Feature Services
Changelog
7/23/26: Experience Builder 1.21 compatibility (v1.0.2)
EB Developer Edition 1.21 (JS API 5.x) broke parts of the widget UI. All resolved below. The widget remains compatible with 1.20.
- Fixed the measurement panel layout in 1.21: the label and value ran together on one line ("Distance378.15 ft") and the panel lost its padding and was cut off. The panel is now styled independently of Esri's internal class names, so it renders correctly on both versions and will survive future Esri DOM changes.
- Fixed What's Here popup styling in 1.21: list rows, the Back and Zoom to buttons, and links rendered unstyled because the popup now places content inside a shadow root that page-level stylesheets cannot reach. Styles are now applied directly to the popup content. The resizable popup also works across the 1.21 shadow DOM boundary.
- Internal modernization for JS API 5.x: module loading migrated from the global AMD require to the Experience Builder module loader, property watching migrated to reactiveUtils, and length/area calculations fall back to the new geometry operators automatically if Esri removes geometryEngine in a future release.
- Developer experience: added a widget-level tsconfig.json and suppressed TypeScript false positives that appeared in Visual Studio and VS Code after 1.21 relocated several type packages. Editing only, no runtime impact.
7/17/26: Bugfix: Fixed a regression introduced with the mobile long-press feature that made popup text un-selectable and un-copyable in every Experience Builder app containing this widget. The iOS long-press touch-callout suppression was being applied to the entire MapView container, which also holds the popup DOM; because user-select is inherited in the browser, popups inherited the suppression. The suppression is now scoped to the map canvas surface only, so long-press behavior is unchanged and popup text is selectable and copyable again. Existing live sessions are cleaned up on upgrade without needing a map remount.
6/03/26: Enhancements (1.20 version only)
- Add support to launch and open Mailing Labels or Property Report when they are nested in accordion widget (Thank you @KeyHunter for idea and testing)
- Standardized package structure: added package.json, README.md, LICENSE (Apache 2.0), .gitignore, and .npmignore so dependencies install automatically with the standard `npm install` in the client folder. No per-dependency install commands needed.
5/21/26: Enhancements (1.20 version only)
- Open Mailing Labels widget with right click option and apply a buffer prior to sending.
5/12/26: Enhancements (1.20 version only)
- Settings: Import/Export XML so setting configurations can be backed up or transferred between applications.
- Settings/Widget: Enhanced "What's here?" capabilities to drill down into layers more (see video). Supports default settings from webmap or can embed Arcade in settings configuration.
5/7/26: Fix bug with Google Street View not working on 1.20 version.
3/26/26: Resolved issue for 1.20. Version 1.19 and 1.20 available for download. Please report any issues on this blog post.
3/25/26 - No breaking changes, but DE 1.20 creates some bugs I need to troubleshoot
2/17/2026:
2/10/2026:
- Removed 1.18 version, only maintaining 1.19 version
- Removed useless measurement units from pick list (inches, centimeters)
- Removed default Esri measurement total for lines as it caused duplication
- Improved context menu placement to avoid being hidden when a sidebar is expanded
12/10/2025 (for 1.19 version only):
Theme Typography Update – All widget text now uses Experience Builder’s Theme Typography for consistent styling.
Accessibility Improvements – Added multiple WCAG-compliant updates across widgets for better usability and accessibility.
12/03/2025:
- Added a function to allow for any coordinate system for the Copy Coordinates function, not just Web Mercator in the settings panel.
- New function added in 1.19, did not test in 1.18. Article original 1.18 version without new function and 1.19 function with new function. May be backwards compatible in 1.18 but I did not test.
07/23/2025:
- Tested widget on Developer Edition 1.18 that was released on 7/23/25 and widget functions as normal.
06/20/2025:
- Add enhanced marker styling with 7 different shape options (circle, square, cross, x, diamond, triangle, pin)
- Add marker rotation, opacity, and X/Y offset positioning controls
- Add text graphics functionality with custom font controls, outlines, and background options
- Add support for custom coordinate systems via WKID input
- Add coordinate format options (decimal degrees vs degrees/minutes/seconds)
- Add simple marker plotting separate from coordinate markers
- Add comprehensive field selection for feature layers with automatic field loading
- Add popup display customization options (width, height, grouping, field aliases)
- Add real-time graphics counting in clear all option
- Add marker preview functionality in settings interface
- Add enhanced coordinate label positioning and formatting
- Add separate styling controls for coordinate markers vs simple markers
06/13/2025:
- Resolve a bug where browser default window sometimes appear on right click in addition to custom right click window
- Add Pictometry as a right-click option
- Add feature layers to What's Here? function to be queried against
Summary
The Right Click widget enables configurable map-based actions through a context menu. It supports zooming, measurements with filtered unit control, coordinate retrieval, marker and text placement with extensive styling options, and reverse geocoding with feature layer integration. Configuration is available through Developer Edition and applies to connected map widgets.
Feedback on bugs and enhancements can be submitted in the comments section of this blog post.
