Right Click Widget
16291
71
06-11-2025 09:10 AM
Brian_McLeer
MVP Regular Contributor
11 71 16.3K
Introduction
https://github.com/brianmcleer/rightclick-widget
The Right Click widget adds contextual map tools to ArcGIS Experience Builder. When a user right-clicks on the map, a menu appears offering a set of configurable actions. This provides access to functions like zoom, measurement, coordinate copying, marker plotting, text placement, and reverse geocoding.
(view in My Videos)
End User Interaction
Once deployed, users can right-click anywhere on the map to open a context menu. Depending on the configuration, the following actions may be available:
Navigation Actions:
  • Zoom In / Zoom Out: Adjusts the zoom level at the click location
  • Center Here: Pans the map to center on the clicked point
Coordinate Actions:
  • Copy Coordinates: Copies the location to the clipboard using the configured coordinate system
  • Plot Coordinates: Places numbered coordinate markers with configurable styling and coordinate labels
  • Plot Marker: Places simple markers with customizable appearance
Graphics Actions:
  • Add Text: Places custom text graphics on the map with configurable font properties
  • Clear All Graphics: Removes all placed markers and text (displays count when graphics are present)
External Services:
  • Open in Google Street View: Opens the location in Google Street View using projected coordinates
  • Open in Pictometry: Opens the location in Pictometry aerial imagery viewer using projected coordinates
Measurement Tools:
  • Measure Distance / Measure Area: Opens measurement tools with the following features:
    • Automatic segment and total labeling for distance measurements
    • Filtered unit options
    • Single or dual unit display options
    • Close button for tool termination
Information Services:
  • What's Here?: Performs location identification using:
    • Reverse geocoding via configured locator service for address lookup
    • Feature layer queries against configured ArcGIS Feature Services
    • Popup display showing results from both geocoding and feature layer queries
The context menu adapts based on administrator settings. Tools close automatically after use or on map interaction.
Measurement Tools
The measurement functionality includes the following specifications:
Available Units
  • Distance measurements: Feet, Yards, Miles, Meters, Kilometers
  • Area measurements: Square Feet, Square Yards, Square Miles, Square Meters, Square Kilometers, Acres
Unit Display Options
  • Single Unit Only: Displays measurements in the selected default unit
  • Show Both Units: Displays measurements in both the primary unit and its converted equivalent (e.g., "150.00 feet (45.72 meters)")
Interface Elements
  • Distance measurement tool includes a Close button
  • Area measurement tool includes a Close button
  • Default "New measurement" buttons are removed
Coordinate and Marker Plotting
The widget provides two types of marker placement:
Coordinate Markers:
  • Numbered sequentially starting from 1
  • Display configurable coordinate information in popups
  • Support multiple coordinate systems (map native, WGS84, custom WKID)
  • Optional coordinate labels displayed on map
  • Configurable marker styles, colors, outlines, and positioning
  • Support decimal degrees or degrees/minutes/seconds format for lat/lon
Simple Markers:
  • Basic point markers without numbering
  • Fully customizable appearance including style, size, color, outline, rotation, and offsets
  • Support transparency settings
Text Graphics:
  • Custom text placement at clicked locations
  • Configurable font family, size, weight, and color
  • Optional text outlines (halo) and backgrounds
  • Persistent during browser session
(view in My Videos)
Developer Configuration
Map Widget Selection
  • Connects the Right Click widget to map widgets in the application
  • Enables right-click functionality on selected maps
Enabled Actions
Each action can be individually toggled:
  • Zoom In
  • Zoom Out
  • Center Here
  • Copy Coordinates
  • Plot Coordinates
  • Plot Marker
  • Add Text
  • Measure Distance
  • Measure Area
  • What's Here?
Coordinate System Settings
The format for copied coordinates can be configured:
  • Use the current map's coordinate system
  • Use WGS84 (latitude/longitude)
Plot Coordinates Settings
Comprehensive marker configuration options:
  • Coordinate System: Map native, WGS84, or custom WKID
  • Format Options: Decimal degrees or degrees/minutes/seconds for lat/lon
  • Marker Style: Circle, Square, Cross, X, Diamond, Triangle, Pin
  • Visual Properties: Size, color, outline color/width, opacity, rotation angle
  • Positioning: X/Y offset controls for precise placement
  • Text Settings: Number text size and color
  • Labels: Optional coordinate labels with customizable offset, size, and color
  • Popup Content: Toggle coordinate display in marker popups
Simple Marker Settings
Independent styling controls for basic markers:
  • Style Options: Circle, Square, Cross, X, Diamond, Triangle, Pin
  • Appearance: Size, color, outline properties, opacity
  • Positioning: Rotation angle and X/Y offsets
Text Settings
Font and display configuration for text graphics:
  • Typography: Font family, size, weight (normal/bold)
  • Colors: Text color and outline (halo) color
  • Effects: Outline size, optional background color
  • Background: Transparent or colored background options
Reverse Geocoding Configuration
  • Reverse geocoding service URL field for "What's Here?" functionality
  • Optional WKID setting for coordinate projection
  • Feature layer configuration for "What's Here?" queries:
    • Add multiple ArcGIS Feature Service layers
    • Select specific fields to display from each layer
    • Configure search radius and maximum results per layer
    • Set spatial relationship parameters for queries
Feature Layer Configuration
Advanced settings for "What's Here?" functionality:
  • Layer Management: Add/remove feature layers with custom names
  • Field Selection: Choose specific fields to display from each service
  • Service Integration: Automatic field loading from Feature Service URLs
  • Display Options: Configure field aliases and grouping
Popup Display Settings
Customization options for information popups:
  • Layout: Popup width and maximum height settings
  • Content Organization: Show/hide layer names, group by layer option
  • Field Display: Use field aliases or raw field names
  • Styling: Responsive design with scrolling for large content
Measurement Settings
  • Default Units: Select from Feet, Yards, Miles, Meters, or Kilometers
  • Unit Display: Choose between single unit display or dual unit display with conversions
External Service URLs
  • Pictometry Integration: Configure Pictometry service URL with coordinate parameters
  • Geocoding Services: Set reverse geocoding service endpoints
Widget Placement
The widget does not display interface components and operates in the background. Recommended configuration:
  • Set widget size to 0×0 pixels
  • Place in unused corner of the layout
  • Use "Send to back" option in layout settings
  • Keep widget visible and active
  • Recommended for desktop only, not for tablet/phone viewers
Technical Notes
  • Unit dropdown options are filtered to show only the specified available units
  • Invalid unit selections are blocked and revert to default units
  • Console logging is limited to warnings and errors
  • Widget includes cleanup procedures for memory management
  • Graphics persist during browser session but are cleared on page refresh
  • Coordinate projections support multiple spatial reference systems
  • Field metadata is automatically loaded from configured Feature Services
Changelog
7/23/26: Experience Builder 1.21 compatibility (v1.0.2)
EB Developer Edition 1.21 (JS API 5.x) broke parts of the widget UI. All resolved below. The widget remains compatible with 1.20.
- Fixed the measurement panel layout in 1.21: the label and value ran together on one line ("Distance378.15 ft") and the panel lost its padding and was cut off. The panel is now styled independently of Esri's internal class names, so it renders correctly on both versions and will survive future Esri DOM changes.
- Fixed What's Here popup styling in 1.21: list rows, the Back and Zoom to buttons, and links rendered unstyled because the popup now places content inside a shadow root that page-level stylesheets cannot reach. Styles are now applied directly to the popup content. The resizable popup also works across the 1.21 shadow DOM boundary.
- Internal modernization for JS API 5.x: module loading migrated from the global AMD require to the Experience Builder module loader, property watching migrated to reactiveUtils, and length/area calculations fall back to the new geometry operators automatically if Esri removes geometryEngine in a future release.
- Developer experience: added a widget-level tsconfig.json and suppressed TypeScript false positives that appeared in Visual Studio and VS Code after 1.21 relocated several type packages. Editing only, no runtime impact.
7/17/26: Bugfix: Fixed a regression introduced with the mobile long-press feature that made popup text un-selectable and un-copyable in every Experience Builder app containing this widget. The iOS long-press touch-callout suppression was being applied to the entire MapView container, which also holds the popup DOM; because user-select is inherited in the browser, popups inherited the suppression. The suppression is now scoped to the map canvas surface only, so long-press behavior is unchanged and popup text is selectable and copyable again. Existing live sessions are cleaned up on upgrade without needing a map remount.
6/03/26: Enhancements (1.20 version only)
  • Add support to launch and open Mailing Labels or Property Report when they are nested in accordion widget (Thank you @KeyHunter for idea and testing)
  • Standardized package structure: added package.json, README.md, LICENSE (Apache 2.0), .gitignore, and .npmignore so dependencies install automatically with the standard `npm install` in the client folder. No per-dependency install commands needed.
5/21/26: Enhancements (1.20 version only)
  • Open Mailing Labels widget with right click option and apply a buffer prior to sending.
5/12/26: Enhancements (1.20 version only)
  • Settings: Import/Export XML so setting configurations can be backed up or transferred between applications.
  • Settings/Widget: Enhanced "What's here?" capabilities to drill down into layers more (see video). Supports default settings from webmap or can embed Arcade in settings configuration.
(view in My Videos)
5/7/26: Fix bug with Google Street View not working on 1.20 version.
3/26/26: Resolved issue for 1.20. Version 1.19 and 1.20 available for download. Please report any issues on this blog post.
3/25/26 - No breaking changes, but DE 1.20 creates some bugs I need to troubleshoot
2/17/2026:
(view in My Videos)
2/10/2026:
  • Removed 1.18 version, only maintaining 1.19 version
  • Removed useless measurement units from pick list (inches, centimeters)
  • Removed default Esri measurement total for lines as it caused duplication
  • Improved context menu placement to avoid being hidden when a sidebar is expanded
12/10/2025 (for 1.19 version only):
  • Theme Typography Update – All widget text now uses Experience Builder’s Theme Typography for consistent styling.
  • Accessibility Improvements – Added multiple WCAG-compliant updates across widgets for better usability and accessibility.
12/03/2025:
  • Added a function to allow for any coordinate system for the Copy Coordinates function, not just Web Mercator in the settings panel.
  • New function added in 1.19, did not test in 1.18. Article original 1.18 version without new function and 1.19 function with new function. May be backwards compatible in 1.18 but I did not test.
07/23/2025:
  • Tested widget on Developer Edition 1.18 that was released on 7/23/25 and widget functions as normal.
06/20/2025:
  • Add enhanced marker styling with 7 different shape options (circle, square, cross, x, diamond, triangle, pin)
  • Add marker rotation, opacity, and X/Y offset positioning controls
  • Add text graphics functionality with custom font controls, outlines, and background options
  • Add support for custom coordinate systems via WKID input
  • Add coordinate format options (decimal degrees vs degrees/minutes/seconds)
  • Add simple marker plotting separate from coordinate markers
  • Add comprehensive field selection for feature layers with automatic field loading
  • Add popup display customization options (width, height, grouping, field aliases)
  • Add real-time graphics counting in clear all option
  • Add marker preview functionality in settings interface
  • Add enhanced coordinate label positioning and formatting
  • Add separate styling controls for coordinate markers vs simple markers
(view in My Videos)
06/13/2025:
  • Resolve a bug where browser default window sometimes appear on right click in addition to custom right click window
  • Add Pictometry as a right-click option
  • Add feature layers to What's Here? function to be queried against
Summary
The Right Click widget enables configurable map-based actions through a context menu. It supports zooming, measurements with filtered unit control, coordinate retrieval, marker and text placement with extensive styling options, and reverse geocoding with feature layer integration. Configuration is available through Developer Edition and applies to connected map widgets.
Feedback on bugs and enhancements can be submitted in the comments section of this blog post.
71 Comments
Brian_McLeer
Hello @KARIMLABIDI, one difference between my environment and yours is the version of Node.js. I am currently on 24.15.0. and it looks like you are using 26.2.0. The recommended version for Experience Builder Developer Edition 1.20 is Node.js 24. This may not be the reason you are getting the errors, but is a system difference between my setup vs yours.
https://developers.arcgis.com/experience-builder/guide/release-versions/
Brian_McLeer
@KARIMLABIDI did you also update the mailing labels widget if you are using that?
Brian_McLeer
@KARIMLABIDI I think I found the bug in config.json. I updated the 1.20 zip on this blog post. Please let me know if you are still getting the error after you get the latest 1.20 zip from here and confirming you are using the latest mailing labels widget.
KARIMLABIDI
@Brian_McLeer I tried this morning with the updated widget but still the same issue.
I don't use mailing labels widgets so I can't try.
For Node.js,I asked my colleagues to update it, I thought it was the problem 😁.
About the widget, I don't know what to say, I don't understand why it doesn't work now.
I just tried the Enhancement Mesurement widget and they're is the same issue too.The application can't compile and can't be downloaded. I tried with the latest update yet.
On the console, I have messages
Thank you for your help
Brian_McLeer
@KARIMLABIDI can you try the below steps if you feel okay doing so?
  • Close any running EB processes.
  • Delete C:\Users\LABIDI\node_modules entirely.
  • While you're there, delete C:\Users\LABIDI\package.json and C:\Users\LABIDI\package-lock.json if those exist.
  • In your EB folder, delete your-extensions/node_modules/.cache to clear stale resolution.
  • Re-run npm run build:for-download.
KARIMLABIDI
Hello @Brian_McLeer ,
  • Close any running EB processes. OK
  • Delete C:\Users\LABIDI\node_modules entirely.OK
  • While you're there, delete C:\Users\LABIDI\package.json and C:\Users\LABIDI\package-lock.json if those exist.OK
  • In your EB folder, delete your-extensions/node_modules/.cache to clear stale resolution.NOK, I didn't find the .cache file (in client folder?in server folder?)
  • Re-run npm run build:for-download. NOK still get the issue and now I have a error when I put the enhancement mesurement widget.
    I have the same messages when I start the both servers.
    And when I try to donwload, still the same messages.
    Thank you to take time to helping me Brian!
Brian_McLeer
Thank you @KARIMLABIDI , without being able to replicate the issue or see your system fully (not that I am suggesting that), it is hard to troubleshoot and come up with a solution. This widget does not require any npm dependencies beyond what is OOTB of EB, so that should not be a culprit. I am purely speculating on troubleshooting steps below, but might be worth a try.
- Fresh install of 1.20 and put downloaded widgets in ...arcgis-experience-builder-1.20\client\your-extensions\widgets
- Sometimes I have issues with long file paths, so I put my EB DE right on the C drive, that might worth trying so your set up is C:\arcgis-experience-builder-1.20
- If you have not already, try using the suggested version of Node.js for EB DE 1.20
KARIMLABIDI
Hello  ,
I reinstall node.js 24, install a version of my C and the issue is still there.
I tried with EB DE 1.19 and it's the same....
So....
I waste time to install, reinstall, try to download,.... so I suggest you to leave it for now, hoping that the new version of EB will fix the problem.
In any case, thank you for help and for your work!
Brian_McLeer
@KARIMLABIDI after looking at your error more, I strongly think that you are running into a folder path limit, especially since you are using OneDrive. If you are able to deploy EB 1.20 right to your C Drive it may resolve the issue. The errors to me point to a directory issue, and I used to store my EB DE on a deeper folder structure and had similar issues.
Brian_McLeer
@KARIMLABIDI if that does not work, I think because you are getting the error on multiple widgets and it does not seem to be constrained just to right click, your question may get more exposure if you post it to the questions section of the Group Experience Builder Custom Widgets
https://community.esri.com/t5/experience-builder-custom-widgets/bd-p/eb-custom-widgetsforum-board
KARIMLABIDI
@Brian_McLeer  yes I tried with EB on my C: but it was the same issue.
I have the problem juste on your both widget, Enhancement mesurement and Right Click. When I put them off the map, no problem for download the application.
Brian_McLeer
Thank you @KARIMLABIDI , at this point I would recommend posting in the custom widgets link I posted above. I would also normally suggest a support case, but I don't think they will be able to do much with custom widgets involved.
KARIMLABIDI
Thank you @Brian_McLeer  I will post in the custom widgets link and I opened a support case.
KARIMLABIDI
Yes @Brian_McLeer , esri support has pointed some depedencies missing. I installed them and now evrything is ok and working fine! On the both widget.
Thank you @Brian_McLeer !
Brian_McLeer
@Bertrand_Laurancin thank you for your solution and compliments
@KARIMLABIDI glad that you could get it worked out!
Brian_McLeer
KeyHunter
@Brian_McLeerThe right-click does not seem to be engaged for cell phones. Is there a location to activate a two-second hold for right-click?
Brian_McLeer
@KeyHunter currently no, I recommend only use for desktop. When it was developed, mobile/tablet long press was an issue. I can revisit this now that it has been a year and look for a mobile option.
Brian_McLeer
Brian_McLeer
Contributors
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
