"Set As Analysis Input" is not bringing all attributes, Subtypes/Domains to the geoprocessing tool. Where as Table widget is doing. Any solution?
670
06-17-2025 08:28 AM
Vara_PrasadM_S
Hi Team,
When we use 'Set as Analysis input' option from Select widget, the geo processing tool we configured in Analysis widget is not receiving data for all attributes from selected layer and subtypes and domains are also not available from the layer.
However, if we do same 'Set as Analysis input" from Table widget, everything is going fine.
Could you please let me know if its a bug, if there is any work around to continue to use Select widget as our users want to do selection from Select widget and use this 'Set as Analysis input' from Select widget only.
Hi @JeffreyThompson2, could you please help me with this.
Thanks in advance!
DougBrowning
MVP Esteemed Contributor
I was more hoping the Analysis widget can just see the selection from Table or Select widget like it did in WAB.  And its the way Pro works.  Tools have always used the selection in every product but ExB so I am pretty confused on this one.
