Modifying CSS of Original Map Viewer Pop-up (Adding Border Radius)
802
07-07-2025 06:35 AM
Monithor
Hi everyone,
I’ve been exploring ways to customize the pop-up in the original Map Viewer, specifically trying to apply a border radius to give it a more polished look.
I recently came across [@Brian_McLeer]'s right-click widget (really great work, by the way!), and I was inspired to try running a custom widget in the background to apply some CSS changes. However, I haven’t had any success in modifying the default pop-up’s styles — nothing seems to take effect.
Has anyone managed to apply custom styling to the original pop-up, or found a workaround using custom widgets? Any tips or suggestions would be really appreciated!
Thanks in advance!
JeffreyThompson2
MVP Frequent Contributor
https://developers.arcgis.com/javascript/latest/styling/
The Popup is wrapped in Calcite Components so it will probably not respond to standard CSS targeting. You will need to target it through the Calcite Root.
https://community.esri.com/t5/experience-builder-tips-and-tricks/altering-the-calcite-root/ba-p/1608...
GIS Developer
City of Arlington, Texas
