Layer filter is removed when pop-up opens
871
08-07-2024 06:27 PM
MK13
I am running the code below in a custom experience builder widget. It is supposed to filter multiple layers in the map. The filter works as expected but as soon as I click on a feature in the map and the pop up opens, the filter is cleared from all the layers. I expect the filter to be maintained on the layers until I remove it on the click of another button. What could be causing this behaviour?
import { React, type SqlQueryParams, type AllWidgetProps, DataSourceManager, type FeatureLayerDataSource } from 'jimu-core'
import { JimuMapViewComponent, type JimuMapView } from 'jimu-arcgis'
import FeatureLayer from 'esri/layers/FeatureLayer'
import { Select, Option } from 'jimu-ui'
import { FeatureLayerDataSourceImpl } from 'jimu-core/data-source'
import { FeatureLayerDataSourceManager } from 'dist/widgets/common/chart/src/runtime/chart/data-source'
const { useState } = React //{} allow destructuring of this constant
const Widget = (props: AllWidgetProps<any>) => {
  const [jmv, setJmv] = useState<JimuMapView>()
  const activeViewChangeHandler = (jimumapview: JimuMapView) => {
    if (jimumapview) {
      setJmv(jimumapview)
  const addLayerHandler = (evt) => {
    evt.preventDefault()
    //filter all layer views
    jmv.view.map.layers.forEach((lyr) => {
      if (lyr.type === 'feature' && (lyr.title === 'OpenMarketSm' || lyr.title === 'ExclusionZoneSm' || lyr.title === 'ExclusionZoneSm')) {
        let featLyrView = null
        jmv.view.whenLayerView(lyr).then((lyrview) => {
          featLyrView = lyrview
          featLyrView.filter = {
            where: "ServiceAreaType ='Comm. Recycling'"
  return (
      <div>
      <Select
        aria-label="Name"
          placeholder='Select a service type'>
        <Option value = "1">Residential Trash </Option>
        <Option value = "2">Residential Recycle </Option>
        <Option value = "3">Residential Yard Waste </Option>
        <Option value = "4">Commercial Trash </Option>
        <Option value = "5">Commercial Recycle </Option>
        <Option value = "6">Industrial Temp </Option>
        <Option value = "7">Sanitation Services </Option>
      </Select>
      <div>Add Layers to a Map</div>
      <div>
  {props.useMapWidgetIds && props.useMapWidgetIds.length === 1 &&
        (<JimuMapViewComponent useMapWidgetId={props.useMapWidgetIds?.[0]} onActiveViewChange={activeViewChangeHandler}/>)}
      </div>
      <form onSubmit={addLayerHandler}>
        <button className='btn btn-primary'>
          Add Layer to map
        </button>
      </form>
      </div>
export default Widget
//activeViewChangeHandler is called once when the map is ready
// {/* ?. checks if object is null  */}
@Jianxia @JanSarata
MK13
@ojiolkem I suspect that you responded to the wrong post :).
