How do I set default ui language other than english (e.g. Hebrew)?
1811
02-26-2024 08:16 AM
Labels (2)
MichaelLev
by ?locale=he I can set the language, but I want that the default ui language will be Hebrew, and that if the user want English, he will have to set ?locale=en
How do I set that the default ui language will be Hebrew?
Noah-Sager
MichaelLev
Hi @Noah-Sager , I looked at your 2 links but I have not seen a way to set locale to Hebrew without adding "?locale=he" to the url. Have I missed something?
MichaelLev
If I understand correctly - "?locale=he" from url is copied into AppContext.locale interface when the app is loaded and not changed afterwards. If url does not contain "?locale=" then AppContext.locale is not defined, and when EXB opens, it will set the locale to a fixed default value of "en".
What I still do not know is how to cause AppContext.locale to be "he", even without adding "?locale=he" to the url.
In orther words - does React enables it, to "force" AppContext.locale to be "he" as if the user had entered "?locale=he"
