Deleted features are remembered in default - with dirty area
541
01-22-2025 11:50 PM
Labels (2)
EivindAasland
Hi
I have an issue when trying to trace and update a subnetwork.
We get the msg One or more dirty areas were discovered. [[ElectricDevice: {0CD2ED96-5610-4579-80D1-B63F5B8F2EDE}], [ElectricAssembly: {1A89D4D6-F458-4B07-A18A-0CE97C86A1E8}]]
This is usually not a problem, we just fix the issue.
But this is a bit special since this device and assembly i deleted several months ago. They did live in a short period 6th of November 2024 form 11:31 to 12:05
The dirty area exists but not with an area, just a record.
I looks like the deletion is not correctly registered somehow ? I have not found a way to solve this issue, and since this causes a persistent problem with updating this subnetwork it also gives a problem towards operation system etc.
Is there anyway to create this back into deafult with its original globalid, tricking the system to find something we can have validated or deleted again ?
Has anyone had a similar problem and managed to fix it ?
br Eivind
EivindAasland
We had to go into the db and remark as deleted, will demand a bit more then a normal user possibility to fix 🙂
PierreloupDucroix
Did you try to rebuild topology in the area ? It usually solves issues when dirty areas appear where they should not.
CEO of MAGIS
EivindAasland
Hi Pierreloup
No we did not try that in this case, i will keep it in mind if we experience it again and try that first.
Remember we used it "often" in the geometricnetwork, and have seen we have had the need for it in some cases also in UtilityNetwork when some "strange" error where everything seems correctly buildt.
Thanks for the tip.
Br
Eivind
