Unable to complete YPN Survey123
2240
8
12-15-2021 11:16 AM
jamesw
Hello!
I was trying to submit the Survey123 form to request to join the Young Professionals Network, but I am getting the same "You cannot submit records to the survey since you are not field worker or the survey owner." error described by other posts here.
I tried viewing the survey while not logged in to my account, but it had the same result. Is there any current workaround / alternate method for requesting membership?
Thank you,
James
jamesw
Hello Hoon,
I had luck going through the Esri Young Professionals Network LinkedIn page. It sounds like the survey is still not working exactly as intended -- I'd suggest reaching out there instead.
Good luck!
Jeong_HoonKim
Hello, James!
I have the same issue as you. I am curious whether you solve the issue. I appreciate it if you share the updates.
Thank you,
Hoon
jamesw
Hello Hoon,
Good luck!
Jeong_HoonKim
Hello, James!
I joined the YPN via LinkedIn group as well. Thank you so much for sharing!
jamesw
Glad to hear it!
MargaretM
The Survey is still not allowing submissions.
Jeong_HoonKim
Hello Margaret!
I reached out to the Esri Support Team and they are waiting for a response from the relevant team.
I will update the status if I can get some useful information.
Thank you!
WesleySmith
I also am unable to sign up as of 3/3/22. Does anyone know if this has been resolved?
Jeong_HoonKim
Hello, Wesley!
Actually, I communicated on the YPN issue with Esri, but their answer was my role in the organization should be 'field worker' or 'survey owner'. I tried to change my role as those roles in my personal account, but I could not do it since I am the only administrator in my personal account.
During the time I had waited their reply on the issue, I was able to join the YPN via the LinkedIn group. I would recommend you to join the YPN via the LinkedIn group with the following link. You might be able to get a reply from the group within 5 days.
https://www.linkedin.com/groups/6972150/
