May I suggest you to fix this. I am going through this training "Get started with Python in ArcGIS Pro" in the Tutorials in the Learn ArcGIS or Tutoral Gallery| Documentation section.
What I found is a missing is that it is diffcult to know which version the IDLE is... Let me show you
No mention of which version IDLE it is ? The grey above the menu shows none mention which version it is.
So maybe fix this is to help out the new learners about the IDLE module.
Thank you for the suggestion. When the tutorial is next updated we will include a clarifying graphic.
Click Help. Is there an About option?
Most applications have an equivalent.
Why not use Jupyter notebooks or JupyterLab instead?
I am only suggesting it but just the thought might help for the new people in the future.
