Learning ArcGIS in the "Get started with Python in ArcGIS Pro"
1954
03-18-2025 10:57 AM
DEAF_PROBERT_68
Honored Contributor
May I suggest you to fix this. I am going through this training "Get started with Python in ArcGIS Pro"  in the Tutorials in the Learn ArcGIS or Tutoral Gallery| Documentation section.
What I found is a missing is that it is diffcult to know which version the IDLE is... Let me show you
No mention of which version IDLE it is ?  The grey above the menu shows none mention which version it is.
So maybe fix this is to help out the new learners about the IDLE module.
BobBooth1
Thank you for the suggestion.  When the tutorial is next updated we will include a clarifying graphic.
DanPatterson
MVP Esteemed Contributor
Click Help.  Is there an About option?
Most applications have an equivalent.
Why not use Jupyter notebooks or JupyterLab instead?
... sort of retired...
DEAF_PROBERT_68
Honored Contributor
I am only suggesting it but just the thought might help for the new people in the future.
BobBooth1
