How to Create Custom Roles in ArcGIS Enterprise
2764
11-15-2023 09:03 AM
TravisSaladino
ArcGIS Enterprise lets administrators make custom roles to coordinate permissions with the business needs of the members of your organization. Learn the process through this quick example where I make two custom roles to coordinate content management and content creation in a portal.
The video was recorded using ArcGIS Enterprise11.1 in November 2023.
For further ArcGIS Enterprise training, check out Esri's ArcGIS Enterprise: Configuring a Base Deployment course: https://go.esri.com/base-deployment-course.
BrandyAD
@TravisSaladino
Can custom roles be made for field workers especially with the ability to work with offline areas?
TravisSaladino
Hi Brandy.
Great question. There are a range of permissions that can be adjusted for custom roles. They are all documented in the online help here. There is a lot that could be covered by "the ability to work with offline areas", but even with that said, there don't seem to be any specific permissions focused on managing offline areas.
I think the limits in place for field workers' interaction with offline maps is controlled by their user type and not as much by the role. Typically field workers are using the mobile worker user type which limits them to only editing features from existing feature layers shared with them. These users cannot make anything new in the portal by license.
There is a great doc at https://www.esri.com/content/dam/esrisites/en-us/media/pdf/implementation-guides/take-your-web-maps-... that goes deeper into the whole process of going offline too.
I hope that helps.
Travis
