Please help me to find out the correct answers in quiz of web course from Esri Academy. As far as I know, there is only one correct answer which is highlighted.
In ArcGIS Online, in which two ways can you add a CSV file to a map to visualize the locations?
Choose two answers.
- Enter the file name in the search field.
- From the Add menu, choose Add Layer From File.
- Drag the file from File Explorer into the map.
- Right-click the map and choose Add Data.
 - Right-click the Content pane and choose Add File.
Hi, our team has confirmed that this quiz question does have two correct answers and the course quiz grading tool is correctly set.
Hi, thanks for posting. Our team will look into the exam issue.
