For "ArcGIS Pro Associate" Certificate, How many answers should be correct to pass the exam?
Thanks in advance.
Well. The cut-off mark is not known (or published).
But you need to pass in all sections (05) mentioned under Skills Measured.
EAPA2101 V4.20211222.pdf (esri.com)
My suggestion: Prepare well for all the sections and attempt the exam to the best of your knowledge.
Steps to Certification Success - Esri Community
Esri ArcGIS Pro Associate Certification 2101 | Learning Plan
