ArcGIS Pro Associates2025_Exam Pattern
2788
04-08-2025 01:14 AM
KamalKantVerma
Is there any difference in marking if we take the exam at home or in a Pearson VUE centre (result - Pass / Fail)?.
How many questions will be correct out of 75 if the person passes the exam? OR as per the below-mentioned % for each measurement criteria.
  1. Data Management 32%
  2. Visualization 25%
  3. Layouts and Sharing 18%
  4. Analysis and Geoprocessing 25%
2 Solutions
JenniferParra
Our exam forms are delivered and scored the same way whether it’s done at a Pearson testing center or online through OnVUE. Each of our exams are scored out of 65 questions and those questions are allocated based on the section percentages you have listed. Please refer to our What to Expect on Your Esri Certification Exam article to learn more about scored/unscored questions and overall information on what to expect.
Our program agreement (Article 5 – Exam Results) and our website’s Scoring Tab, provide information about exam results. Unfortunately, to maintain exam security, we are not able to provide candidates with answers to exam questions, whether an exam answer affected candidate's pass or fail status rating, or the score that is required to obtain a pass rating. We can tell you that Pass/Fail Ratings provided in your score report is set using statistical analysis. Esri does not publish or disclose Operational Exam or Beta Exam passing scores but we will supply candidates with a pass/fail rating on all level exams.
I hope this information was helpful!
JenniferParra
Hi @KamalKantVerma thanks for reaching out. Your first attempt at the exam needs a voucher as payment; the promo is for subsequent retakes. Here is an article that outlines how to purchase and apply your voucher to an appointment: Esri Exam Voucher Purchase and Registration. Before you do this, however, ensure you are opted into the promo. Here is an article that outlines the steps for the retake promo: 2025 Free Certification Exam Retake Promotion.
JenniferParra
KamalKantVerma
Hi Team,
I'm facing the attached issue while enrolling myself for the Esri certification exam under the Retake Policy. Please suggest
Kamal Kant Verma
JenniferParra
