The Enterprise Administration Professional exam validates skills related to deploying
ArcGIS Enterprise; configuring, maintaining, and troubleshooting the core components; and managing updates to services and apps. This exam will test the candidate’s experience applying these skills and processes to support enterprise GIS workflows.
The Enterprise Administration Professional exam is for candidates with experience applying ArcGIS concepts and processes to relative workflows. It is recommended candidates have at least 2 years of experience installing, configuring, and supporting ArcGIS Enterprise. Target audience is also candidates who have the following or similar roles: ArcGIS Enterprise administrators, ArcGIS consultants, System integrators, System administrators, GIS managers.
The Enterprise Administration Professional exam is designed for candidates with at least two years of knowledge, understanding, and experience with ArcGIS Enterprise. It is recommended that the candidate have extensive experience implementing and administering ArcGIS Enterprise according to Esri best practices. A qualified candidate can troubleshoot common technology issues and distinguish between ArcGIS Enterprise components and supported systems issues, such as RDBMS and web servers.
A qualified candidate should be able to perform the following tasks:
The following tasks are considered beyond the knowledge, skills, and abilities of the qualified candidate:
A qualified candidate should be familiar with the following:
Candidates should use the exam content sections below as a checklist to identify gaps between their knowledge and the skills measured by the exam. The relative weight indicates the approximate size of each section. It is recommended that preparation be focused in areas where knowledge gaps are found.
Implement and Deploy ArcGIS Enterprise <Pending Blueprint Survey>
Troubleshoot ArcGIS Enterprise <Pending Blueprint Survey>
Maintain and Support ArcGIS Enterprise <Pending Blueprint Survey>
Manage Content <Pending Blueprint Survey>
To help prepare for the exam, we recommend candidates use the training resources provided below, along with reviewing the list of exam objectives, to identify and fill any knowledge gaps. Completing the recommended training courses does not guarantee a passing score on a certification exam.
The Esri-curated learning plan for this exam is updated regularly to reflect the latest Esri Academy resources and resource retirement schedules.
Esri Academy
Esri Community
Link to ArcGIS Documentation
We hope you will subscribe to this article to keep up to date with the progress of this exam update and click this link to Ask Questions.
