2025 Exam Version - Available to Public | 2101 Exam Version – Retired 30 June 2025 |
Data Management - 32% | Data Management - 34% |
Manage geospatial data (raster, vector, tabular). | Compare and contrast various types of vector and raster datasets supported in ArcGIS. |
Manage coordinate systems to preserve the desired spatial properties. | Choose and apply an appropriate coordinate system to preserve the desired spatial properties. |
Given a scenario, determine the appropriate existing geodatabase elements to use. | Given a scenario, determine how to manage data in a geodatabase, feature class, or table. |
Use ArcGIS Pro editing functionality to create, modify, and delete features and attributes. | Apply spatial and attribute data validation. |
| Manage raster data, tabular data, and vector data. |
| Manage metadata and item details |
N/A | Data Manipulation - 19% |
| Use ArcGIS Pro editing functionality to create, modify, and delete 2D and 3D data. |
| Resolve the root cause of a data alignment problem. |
| Given a scenario, apply a query. |
| Troubleshoot data anomalies with tabular and vector data |
Visualization - 25% | Visualization - 14% |
Identify how to control the coordinate system and geographic transformation in ArcGIS Pro. | Identify how to control the coordinate system and geographic transformation in ArcGIS Pro |
Manage layer properties using the ribbon and dialog boxes. | Manage layer properties. |
Determine how to visualize temporal, ranged, or 3D data. | Determine how to visualize temporal, ranged, or 3D data. |
Given a scenario, apply a query. | |
Layouts and Sharing - 18% | Sharing - 11% |
Identify how to export data, maps, and scenes to different formats. | Identify how to export data, maps, and scenes to different formats. |
Choose how to share content from ArcGIS Pro. | Choose how to share content across ArcGIS. |
Determine how to create and manage map layouts and map series. | Determine how to create and manage map layouts and map. |
Analysis & Geoprocessing - 25% | Analysis & Geoprocessing - 23% |
Compare the functionality of table joins and relates, relationship classes, and spatial joins. | Compare the functionality of table joins and relates, relationship classes, and spatial joins. |
Given a scenario, determine the appropriate geoprocessing tool to use. | Given a scenario, determine the appropriate geoprocessing tool to use. |
Given a scenario, use tasks, batch processing, models, or scripts to execute a complex workflow. | Given a scenario, use tasks, batch processing, models, or scripts to execute a complex workflow. |
Apply raster functions for raster and image processing. | Identify analysis tools available from the connected portal. |
