Activation code
1422
05-11-2021 11:16 AM
SunShines
I purchased an eBook for class and it did not have the activation code with the electronic book. I need help getting a student activation code asap... Can anyone help me? I used the ISBN 9781589485112
Craig_Carpenter
More info about EVA codes for e-books can be found here.
JayantaPoddar
Do you see an EVAxxxxxxxxx code printed on the inside back cover of your book (Don't mention it here, in case you see it)?
Select the appropriate eBook to activate your trial activation code using the activation code from https://esripress.esri.com/display/dsp_arcgis10eval.cfm
You may reach out to Esri Technical Support for help, if required.
Think Location
Craig_Carpenter
