java.lang.NullPointerException
8034
11-02-2010 11:50 PM
PrimozKogovsek
Hello
I have problem setting up geoportal extension 10
Server description:
OS: Windows server 2008 32-bit
ESRI: ArcGIS Desktop 10, ArcGis Server 10, Geoportal 10
Database: Oracle 11g rac
Java: jdk 6.0.21
Servlet: Tomcat 6.0.29 (location c:\Program Files\Apache Software Foundation\Tomcat 6.0\)
ldap: windows active directory
I put up geoportal and run in to problem when try to administer data, when I open administration tab I get message: java.lang.NullPointerException
Log looks like this:
28.10.2010 13:31:34 com.esri.gpt.framework.jsf.BaseActionListener handleException
SEVERE: Exception raised.
at com.esri.gpt.framework.sql.DatabaseReference.openJndiConnection(DatabaseReference.java:269)
at com.esri.gpt.framework.sql.DatabaseReference.openConnection(DatabaseReference.java:223)
at com.esri.gpt.framework.sql.ManagedConnection.<init>(ManagedConnection.java:41)
at com.esri.gpt.framework.sql.ManagedConnections.returnConnection(ManagedConnections.java:121)
at com.esri.gpt.framework.sql.ConnectionBroker.returnConnection(ConnectionBroker.java:85)
at com.esri.gpt.framework.sql.BaseDao.returnConnection(BaseDao.java:157)
at com.esri.gpt.framework.security.identity.local.LocalDao.ensureReferenceToRemoteUser(LocalDao.java:94)
at com.esri.gpt.framework.security.identity.ldap.LdapClient.populateUser(LdapClient.java:416)
at com.esri.gpt.framework.security.identity.ldap.LdapClient.authenticate(LdapClient.java:244)
at com.esri.gpt.framework.security.identity.ldap.LdapIdentityAdapter.authenticate(LdapIdentityAdapter.java:64)
at com.esri.gpt.control.identity.LoginController.processSubAction(LoginController.java:132)
at com.esri.gpt.framework.jsf.BaseActionListener.processAction(BaseActionListener.java:271)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.sun.faces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:126)
at javax.faces.component.UICommand.broadcast(UICommand.java:305)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:267)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:381)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:75)
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:90)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:197)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.esri.gpt.control.filter.EncodingFilter.doFilter(EncodingFilter.java:100)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:619)
28.10.2010 13:31:38 com.esri.gpt.framework.jsf.BaseActionListener handleException
at com.esri.gpt.catalog.arcims.ImsPermissionDao.preparePublisher(ImsPermissionDao.java:125)
at com.esri.gpt.framework.security.principal.Publisher.<init>(Publisher.java:72)
at com.esri.gpt.control.publication.ManageMetadataController.processSubAction(ManageMetadataController.java:539)
I cannot import metadata (from file and catalog) neither create it using geoportal templates.
Database schema has only empty tables.
Did I get wrong somewhere in configuring geoportal or it is something ellse? (see attached files)
thanks,
Primoz
MartenHogeweg
hi,
couple of questions:
are you able to log in to your configuration?
can you increase the logging to FINEST and retry?
can you share the metadata you are trying to publish?
regards,
Marten
CliveReece
Primoz,
Please let us know the outcome from Marten's questions above.
I would also suggest making sure you start with clean logs for troubleshooting: Shutdown Tomcat; Go to the Tomcat logs directory; delete the logs (archive them somewhere else if you need); Restart Tomcat.
Now that you have clean logs, *wait* (don't connect to geoportal) and go inspect the logs for any errors. Then sequentially proceed with connecting to geoportal, and checking the logs for new messages after *each* interaction with geoportal. This troubleshooting procedure helps me narrow down issues quickly.
The only oddity I noticed in your gpt.xml file is in the ldapAdapter section where you define the gptRegisteredUser group:
[INDENT]<role
key="gptRegisteredUser"
groupDN="CN=gptRegisteredUser,CN=Users,DC=nt,DC=arso,DC=sigov,DC="/>
[/INDENT]
The last 'DC=' is missing an entry. All the other DNs end with a 'DC=si' in your configuration. Could you check that?
Clive
PrimozKogovsek
Ok
In attachment i left you the tomcat logs.
It seems the problem is in connection to oracle trough JDBC.
I google it up a little and found this:
http://codingexplorer.wordpress.com/2009/05/07/the-reason-behind-oracle-11g-severe-error-while-regis...
@ clive
Thanks i will reper this
any ideas?
Primoz
PrimozKogovsek
Success!
The problem was in jdbc configuration. This configuration works fine for me:
<Context docBase="geoportal" path="/geoportal" debug="0" reloadable="true" crossContext="true">
          <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource"
                 driverClassName="oracle.jdbc.driver.OracleDriver"
                 url="jdbc:oracle:thin:@host:port/service name"
                 username="username"
                 password="password"
                 maxActive="20"
                 maxIdle="10"
                 maxWait="-1" />
         </Context>
Now i have to test everything...
Primoz
P.S. didn`t mean to post smilies, but i dont know hov to get rid of them
