I used Publish Client bulk metadata portal. The tool is configured correctly according to ESRI tutorial, as PublishClient.properties file to view the log files. However the file. log does not show on the road that had been set.
On the other hand, the initial charge was performed without problems, however at a given time, the tool stopped working when they had loaded 10000 metadata and load remain to 6000.
In short I have two problems:
1. We can not access the log file for the cause of the problem
2. We can not continue loading metadata portal
Does anyone have an idea of how to access the file and / or limited because of the burden of metadata?
PS: sorry for my English
