Geoportal search error
3239
6
03-12-2012 04:25 AM
PaulBelew
Hi!
Can anybody help?
We've configured geoportal and added some resources.
When search page "Search" button was clicked the error occured:
Unable to load /geoportal/rest/find/document?rid=local&ridName=This%20Site&rids=local&searchText=ewrew&start=1&max=10&orderBy=relevance&maxSearchTimeMilliSec=10000&f=searchpageresults&dojo.preventCache=1331554401446 status:500/geoportal/rest/find/document?rid=local&ridName=This%20Site&rids=local&searchText=ewrew&start=1&max=10&orderBy=relevance&maxSearchTimeMilliSec=10000&f=searchpageresults
Could not perform operation.
The configuration: SQL Server 2005, GlassFish
PaulBelew
The Log had error: LuceneConfig indexLocation is empty.
indexLocation parameter was set on existing folder path.
The error has gone.
But search results are empty. And the catalog is empty.
PaulBelew
Server and client restart.
CliveReece
So, you did go back and set the lucene indexLocation to a good path in gpt.xml?  Yes?
Are you still seeing errors in the logs?
ElfLittle
I met the problem too...
how can I config the indexLocation..thx
PaulBelew
Exactly! And no errors.
PaulBelew
Create folder and set indexLocation to this path
