Geoportal: A database communication error has occur
6489
11
05-24-2011 01:56 PM
Mirza_MuhammadWaqar
HI
Whenever I try to login with admin, publisher or registereduser in geoportal the following error displays:
"A database communication error has occur."
What am I missing?
Mirza Waqar
ErosSy
hello
with same problem I've solved:
replacing the username="geoportal" property by user="geoportal" in geoportal.xml
helped me a lot.
the root cause was specifying the "type" & "factory" value from geoportal.xml (context.xml)
the specified api uses the "user" not "username" property.
Which is not documented.
Thanks a lot. sbruscoli
AndrzejBieniek
Below is working geoportal.xml file (using Oracle Service name)
server_name must be replaced by your real server name
service_name must be replaced with your real service name like ORCL
<!-- Context configuration file for the Geoportal Web App -->
<Context docBase="geoportal" path="/geoportal" debug="0" reloadable="true" crossContext="true">
  <Resource name="jdbc/gpt" auth="Container"
            type="oracle.jdbc.pool.OracleDataSource"
            driverClassName="oracle.jdbc.driver.OracleDriver"
            factory="oracle.jdbc.pool.OracleDataSourceFactory"
            url="jdbc:oracle:thin:@//server_name:1521/service_name"
            user="geoportal"
            password="geoportalpwd"
            maxActive="20"
            maxIdle="10"
            maxWait="-1" />
</Context>
Depending if u are using SID or ServiceName URL is different:
 jdbc:oracle:thin:[USER/PASSWORD]@[HOST][:PORT]:SID
 jdbc:oracle:thin:[USER/PASSWORD]@//[HOST][:PORT]/SERVICE
Sample connect string:
url = "jdbc:oracle:thin:@//myhost:1521/orcl"
url = "jdbc:oracle:thin:@myhost:1521:orcl"
I hope it helps.
regards
