ArcGIS Portal and ArcGIS Geoportal
3971
07-19-2011 03:09 AM
PaulLohr
Does the ArcGIS Geoportal contain the components necessary to build an ArcGIS Portal? By ArcGIS Portal, I am talking about a website built with the framework of ArcGIS Online but customized for the needs of the organization. The portal has been mentioned in a few places but I'm not sure where to get the components to build it or what licensing is required.
Thanks for any help,
Paul Lohr
CliveReece
short answer:  no
They are two separate products with different components and code bases.  Esri ArcGIS Portal is a commercial product.  Esri Geoportal Server is an open source product.
tongkimongki
I install Arcgis Portal and Geoportal in the same server. Arcgis Portal works, but Geoportal doesnt. Geoportal gives me error like this :
HTTP Status 500 -
type Exception report
message
descriptionThe server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: ServletException in '/catalog/skins/centeredLayout.jsp': com.sun.faces.mgbean.ManagedBeanCreationException: Unable to set property searchCriteria for managed bean SearchController
root cause
javax.servlet.ServletException: ServletException in '/catalog/main/homeBody.jsp': Unable to set property searchCriteria for managed bean SearchController
root cause
org.apache.jasper.JasperException: com.sun.faces.mgbean.ManagedBeanCreationException: Unable to set property searchCriteria for managed bean SearchController
root cause
root cause
com.sun.faces.mgbean.ManagedBeanCreationException: Unable to set property searchFilterUri for managed bean SearchCriteria
root cause
com.sun.faces.mgbean.ManagedBeanCreationException: Unable to set property selectedHarvestSiteName for managed bean SearchFilterHarvestSites
root cause
java.lang.NullPointerException
I am using Linux RHEL 5.6 64 bit.
What I do are:
1. Install the Arcgis Portal (this will automatically install jdk1.6.0_23, Glassfish 2.1.1)
2. Install Geoportal 0.9
My guess is that the Java version isnt compatible...
Please help... thanks
Note : I actually succeeded in installing Geoportal 1.1 (only Geoportal) in Windows Server 2008. I use jdk-6u26 and Glassfish 3.1 (with openDS in other server).
