Moving network points to absolute location using script
4395
03-15-2015 12:45 AM
TanmayNaik
Does anyone have a script or know a inbuilt function of Arc gis 10.1 where i can move points in my created network to their absolute (x,y,z) obtained from gps instruments,
DanPatterson_Retired
load the gps data into a shapefile or featureclass then use it
TanmayNaik
Hello Sir,
Thanks for the information , my query is how do i apply that data to my
existing network to move the points.
and how do i use it as a feature class please elaborate as i am new to this
kind of data transformation.
Thanks & Regards
Tanmay
I was suggesting that you use the gps points if they contained the absolute locations.  If you have existing points and they aren't at their proper location on the network, then you only choice would be to edit your points or, if they are close, specify the tolerance that you consider the points to be on a network whilst building the network.  You don't indicate by example, what you exactly mean by updating their location...are they out by a few meters?, city blocks, totally wrong etc.  A visual of a case would help
