Interpolate a certain range of values in a raster dataset
1444
10-24-2017 04:51 AM
MonaLütjens
Hello everybody,
I am encountering the following problem:
I have an ASTER raster dataset and a bathymetry dataset from a fjord landscape.
My problem is that the bathymetry dataset does not cover values higher than -60 and the ASTER raster does not cover values below 0. Therefore I have the range between 0 and -60 only entered with one single value which gives a very harsh transition.
Is there a workflow/tool in which I can interpolate the range 0--60 with new values so I get a smooth transition?
I have been looking for quite a while and could not find any answers. Thanks in advance for any suggestions that you might have.
Best regards,
Mona
Tags (1)
DanPatterson_Retired
are two separate images? that you are trying to merge? or two separate data sets that you are trying to interpolate
MonaLütjens
Thanks for you reply. I had two different raster datasets which I have already merged to one. Within this one raster dataset I have this harsh transition I would like to smooth.
You could always export the raster back out to points and reattempt an interpolation from there, but I suspect the results will be less than satisfactory given your description.
Alternately... again, perhaps less than satisfactory... is to run a focal mean over the combined raster to 'smooth' out the transition.  Perhaps a larger window size than the default 3x3 (perhaps 5x5, 7x7) will make it look better.
Smoothing should only be considered a 'look nice' operation in this case
Focal Statistics help topic
