Elevation NED30m extract
3899
6
02-11-2017 12:05 PM
by Anonymous User
Not applicable
I am trying to use the Ground Surface Elevation 30m (href="http://goto.arcgisonline.com/elevation/NED30m) data to do some local processing. I wanted to extract an area and then work with it. But no matter what I do the raster calculator fails with nothing in the output raster. I have checked my environments, I am using a mask, projections are all the same, etc. It takes about an hour to finish (odd I think), the area is less than 50 miles square - this should be a simple process, but after 5 tries I am ready to abandon and just download the data and use it.
I am working in ArcMap 10.5, using Spatial Analyst and all Esri tools.
Any recommendations?
Lorri
DanPatterson_Retired
try the original sources would be my suggestion.  The two comments seem to suggest that you may be experiencing a similar fate
AbdullahAnter
Honored Contributor
Are you sure that there are areas equal 30m?
maybe 30.1/ 29.9/30.08 ...etc. Do you want over 30 m or equal?
try use Extract by Attributes tool  Extract by Attributes—Help | ArcGIS Desktop rather that raster calculator.
try to do mask the output in environment, but let the tool run then use Extract by Mask Extract by Mask—Help | ArcGIS Desktop .
I hope this be helpful.
If I am not mistaken, it is the source of the data from ArcGIS Online that is the problem.  The original sources may be a better option since there are fewer restrictions on its use
AbdullahAnter
Honored Contributor
Lorri
So I think she can use Arc Map Desktop.
That is good... because, it would be best to download the data from the original source and use it since the source being used isn't the original
by Anonymous User
Not applicable
I just downloaded the data for the quads I needed and processed this successfully. I agree that it seems the data on AGOL was not functioning as expected.
