ArcGIS Pro mosaic checkerboard
1238
05-02-2018 04:06 PM
VeniaminYampolsky
A mosaic of 3DEP rasters appears properly when zoomed in close, but becomes checkered when zooming out. Visibility range is set to <None> for both min and max scales. All source rasters are saved in the same workspace. ArcGIS Pro version 2.1.2
JakeSkinner
Esri Esteemed Contributor
Hi Veniamin,
Did you build overviews for the mosaic dataset:
Build Overviews—Data Management toolbox | ArcGIS Desktop
Try executing this tool with the default settings and see if you can view the mosaic dataset at smaller scales (zoomed out).
