Utility Network for Utility Network Management Extension (Esri)
21318
75
01-25-2018 05:03 PM
SpatialNinja
With the release of ArcGIS Enterprise 10.6 and ArcGIS Pro 2.1, the Utility Network Management extension is offered as a comprehensive solution to managing utility and telecom networks (telecom model not available with first release). Core tools within the Utility Network Toolbox can be used to create and configure the utility network. For automation purposes, the Utility Network Package Tools from the ArcGIS solutions team are available with asset packages for electric, gas, and water domains.
Use this discussion thread to voice any questions and discuss the new Utility Network on the Utility Network Management Extension.  Learn More: https://blogs.esri.com/esri/arcgis/2018/01/23/vision-and-overview-of-the-utility-network/
ArcGIS Utilities Team
Join the Discussion Below!
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
JamesFarmer
What is the time frame for a configuration for Electric Transmission to be released?
HowardCrothers
jfarmer08 We anticipate releasing the Electric Transmission Utility Network Configuration July 2018, right before the User Conference.
JamesFarmer
Great! Thanks!
HungTruong
Hi UN team,
I am able to configure Gas Utility Network from the gas_asset package. When I deploy Gas Network Editor from ArcGIS Solutions, I get an error message: Could not convert string to float: '2.1.1'
Gas Network Viewer is deployed successfully.
Any ideas to fix this?
Hung Truong
AltaGas Utilities Inc.
PaulLeBlanc1
We've found the issue and are currently testing the fix. Thanks for reporting!
PaulLeBlanc1
A new version of the add-in has been released. Let us know if you still experience the same issue.
HungTruong
It's fixed. Thanks for the quick fix.
RajeshMane3
Thanks, By when Utility Network configuration extension would be released for Telecommunication data model
HowardCrothers
Currently planned for Q2 2019
SpatialNinja
For the latest updates on the telecom data model, you can follow this discussion thread.
https://community.esri.com/thread/202473-telecom-network-for-utility-network-management-extension
