How to convert DJI Inspire 1 .SRT file into Metadata for FMV?
4270
05-30-2016 12:30 PM
AaronWoods
Aloha everyone.
I'm trying to figure out the best way to get good quality Metadata from my DJI Inspire 1 in order to use videos in the updated FMV add-on.  I've found the .SRT file but it doesn't seem to have nearly as much "info/Data" as I had hoped, given what appears to have been captured when reviewing the flights on the DJI-GO app.    When I open the flight .SRT file, it shows the info below (Sample data point from several hundred)...
00:00:04,000 --> 00:00:05,000
HOME(-158.1028,21.5926) 2016.05.29 13:30:42
GPS(-158.1028,21.5926,14) BAROMETER:0.1
ISO:136 Shutter:30 A:10 AA:10 EV: 0 Fnum:F2.8
I've used Subtitle Edit software to convert the .SRT into a CSV that then requires a bit more parsing in Excel  but then only end up with the following Info in a CSV....
**Metadata ID
** Start time --> end time
** Home co-ordinates Date & Time
** Current GPS co-ordinates of the bird, Barametric Height
** iso info, Camera info, Shutter, Some values A, & AA along with EV & Fnum
Any idea how best to map this to Video Multiplexer MISB Field Mapping Template provided with FMV?  I also found a GitHub script that appears to be intended for the Phantom 3, but am struggling with how to make it work as well.
Mahalo Nui Loa for any tips/tricks or advice. Cody Benkelman
