Why does arcpy.mp.ArcGISProject() give an OSError?
17015
11
06-01-2017 08:07 PM
MatthewCallahan1
I read the "Guidelines for arcpy.mp" doc, but when I call the sample code myself in the ArcGIS Pro Python window or from a Python script, I get this error:
import arcpy
aprx = arcpy.mp.ArcGISProject(r'C:\Path\To\Project\test_project.tbx')
Runtime error
  File "<string>", line 1, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\_mp.py", line 283, in __init__
    self._arc_object = arcgisscripting._mapping.ArcGISProject(*gp_fixargs((aprx_path,), True))
OSError: C:\Path\To\Project\test_project.tbx
Is this normal expected behavior?  The example code shows setting the project variable with an explicit .aprx file path, and I'm wondering why I'm unable to do the same on my machine.  The .aprx file is present/there are no misspellings in the file path in my code.  For reference, I'm running a fresh Windows 7 64-bit install with a fresh ArcGIS Desktop install as well (Pro v 1.4.1).
AllenDailey1
You're welcome @Sean-Sweeney !  Thanks so much for your comment; I'm so glad to know that my comment was useful for someone!
StefanUseldinger
The OSError also appears when calling .save() while the project is still open on a different machine.
