Why does arcpy.mp.ArcGISProject() give an OSError?
17055
11
06-01-2017 08:07 PM
MatthewCallahan1
I read the "Guidelines for arcpy.mp" doc, but when I call the sample code myself in the ArcGIS Pro Python window or from a Python script, I get this error:
import arcpy
aprx = arcpy.mp.ArcGISProject(r'C:\Path\To\Project\test_project.tbx')
Runtime error
  File "<string>", line 1, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\_mp.py", line 283, in __init__
    self._arc_object = arcgisscripting._mapping.ArcGISProject(*gp_fixargs((aprx_path,), True))
OSError: C:\Path\To\Project\test_project.tbx
Is this normal expected behavior?  The example code shows setting the project variable with an explicit .aprx file path, and I'm wondering why I'm unable to do the same on my machine.  The .aprx file is present/there are no misspellings in the file path in my code.  For reference, I'm running a fresh Windows 7 64-bit install with a fresh ArcGIS Desktop install as well (Pro v 1.4.1).
DanPatterson_Retired
from the help topic why don't you reference the *.aprx, then you can get the toolbox as one of its properties.  You are referencing the toolbox (tbx) directly.
MatthewCallahan1
lol I'm dumb, that was it!  Time for bed, enough Python for today!
KevinChristy1
Dan, might you know why one would get this same exact error, but I am actually referencing the *aprx file?
MichaelVolz
Esteemed Contributor
Would you need to use Current in this circumstance?
KevinChristy1
Disregard, I realized that due to the nature that my project file and .aprx had the same name that I was omitting the project folder...Thanks though!
ShraddhaSharma
Hi Dan I am also facing the same problem but with my aprx file.
AllenDailey1
I'm having the same error, but with my .aprx path, not with a toolbox path.  Have any of you been able to solve the problem?
Thanks!
AllenDailey1
I think I figured it out.  I haven't 100% tested this yet, but I believe the error resulted from the .aprx being Pro 3.0 while the machine I was running my script on had Pro 2.7, so it could not open or use the .aprx.  I am going to upgrade that machine to Pro 3.0 sometime this week.
Update:  it worked!
Sean-Sweeney
Thank you @AllenDailey1! Five minutes of Googling just saved me who knows how many hours of debugging.
