Using SQL script to edit a named version in SQL Server Manager?
1062
09-28-2023 08:04 AM
RPGIS
by MVP Regular Contributor
I am trying to figure out how to edit a named version using a sql script and I am not sure how to go about it. I can pull the named version information, but I am not sure how to update the information in the table.
Here is what I have thus far.
EXEC [Database].sde.edit_version 2, 1; -- opens edit session on version
EXEC [Database].sde.set_current_version 2; -- Sets version to access
BEGIN TRY
BEGIN TRANSACTION [Tran1]
MERGE [Database].[Featureclass_evw] as TargetTable
USING [Server].[Database].[dbo].[Table] as SourceTable
ON TargetTable.[MatchingColumn] = SourceTable.[MatchingColumn]
WHEN MATCHED THEN
  UPDATE SET TargetTable.[ColumnA] = SourceTable.[ColumnB]
COMMIT TRANSACTION [Tran1] -- if successful will commit the transaction
END TRY
BEGIN CATCH -- if error occurs, will rollback the transaction
    ROLLBACK TRANSACTION [Tran1]
END CATCH
EXEC [Database].sde.edit_version 2, 2; -- ends the edit session
I have also tried this option below.
BEGIN TRY
UPDATE [sdeowner].[Featureclass_evw]
SET [Field] = (
SELECT A.[Field]
FROM [Server].[Database].[dbo].[Table] AS A
JOIN [SDEOwner].[Featureclass_evw] ON [SDEOwner].[Featureclass_evw].[Field] = A.[Field]
WHERE EXISTS (
	SELECT 1
	WHERE [Field] = [SDEOwner].[Featureclass_evw].[Field]
END TRY
END CATCH
I cannot seem to update the values based on these sql queries so I am stuck for the time being. Any help on this would be greatly appreciated.
