Update Arcgis Server from 10.2 to 10.3 (Windows 2008/IIS)
3625
11-05-2015 01:28 AM
EsperanzaBravo_Igual
In my installation I have open two ports without redirect from 6080 to 6443 with SSL.
And now I´ve tried to update the AGS 10.3, but always I have the port redirect to 6443.
I´ve installed webadaptor.
is there any way to have both ports without a redirect?
Thanks you
Do you have any idea?
Thank you!
RebeccaStrauch__GISP
from the help...
Ports used by ArcGIS Server—Documentation (10.3 and 10.3.1) | ArcGIS for Server
http://server.arcgis.com/en/server/latest/administer/windows/ports-used-by-arcgis-server.htm
HTTPS port 6443
When SSL is enabled, ArcGIS Server uses port 6443 by default.
Using a different set of port numbers
If you want ArcGIS Server to use a different set of port numbers, log in to the Administrator Directory and click machines > <Machine Name> > edit. In the list of ports, type the new port numbers you want to use and click Save Edits. You can do this on each GIS server participating in the site if desired.
And you may want to read thru this too.
Supporting a mix of public and private services—Documentation (10.3 and 10.3.1) | ArcGIS for Server
typically the 6080 and 6443 are the internal ports, and the web adaptor uses 80 and 443, and are http and http so respectively.  You can use the REST admin to set your system to " http and https" or " http so only"   ....I don't recall what the default it if you install SSL .
