Understand Mobile Geodatabases
2760
03-03-2021 05:15 AM
JoseSanchez
Hello everyone,
I have a several questions  related to mobile geodatabases.
Can I open a mobile .geodatabase with ArcGIS desktop or do I need ArcGIS Pro?
Can I create  a .geodatabase with ArcGIS Desktop?
Can a mobile .geodatabase point directly to SDE or do I need a synchronization tool to refresh the database?
How can I view an exiting .geodatabase with ArcGIS desktop and ArcGIS Pro?
How can I add/remove layers to a mobile .geodatabae with ArcGIS Desktop or ArcGIs Pro?
Thank you.
DanPatterson
MVP Esteemed Contributor
Some of your answers are here
Mobile geodatabases—ArcGIS Pro | Documentation
They are new to ArcGIS Pro 2.7  are stored in an SQLite database
Then the warning
All mobile geodatabases are stored in SQLite databases, but not all SQLite databases are mobile geodatabases.
size and limitations
Mobile geodatabase size and name limits—ArcGIS Pro | Documentation
and not a mention of SDE anywhere
... sort of retired...
JoseSanchez
Can I create a mobile .geodatabase with ArcGIS desktop?
Can it be done creating and  ArcGIS Runtime content?
DanPatterson
Don't know about the latter, you will have to check the appropriate help documents
by Anonymous User
Not applicable
All of the demos show them creating mobile geodatabases in Pro, emailing them, and opening them in Pro.
Isn't the intent to be able to use them in mobile apps like Field Maps or the ArcGIS Runtime API for Android?
The 100.12 release notes for Android state they can be Read and edit standalone mobile geodatabases
We were able to sideload them to a directory within our mobile app and read and edit it in our Runtime app.
Is that the point of these things?
For it to work in Field Maps, it seems they may have to be part of a mmpk? But then is the mobile gdb really standalone? And are mmpks no longer read-only then?
