Two different desktop developer kits together
2566
06-22-2016 08:00 AM
SeanPack
Hello,
I have ArcGIS 10.3 loaded with the 10.3 developer kit that I use with Visual Studio 2013. If I also have Visual Studio 2010 loaded, can I load the 10.2 developer kit alongside the 10.3 version and use it with VS2010?
FreddieGibson
Honored Contributor
Do you mean that you have ArcGIS for Desktop, Engine, or Server 10.3 installed with the ArcObjects SDK 10.3? If so, you would not be able to install version 10.2 of the developer kit because these products do not allow side-by-side installs.
SeanPack
Hi Freddie,
Yes, I have ArcGIS for Desktop 10.3 loaded with the ArcObjects SDK 10.3. Your answer suggests that the SDK is not standalone, but rather relies on some components that are installed with the version of the desktop software a user has -- is that correct? I was thinking/hoping that the SDKs were standalone.
--Sean
FreddieGibson
Honored Contributor
The ArcObjects SDK requires that you have one of the following software installed
  • ArcGIS for Desktop
  • ArcGIS for Engine
  • ArcGIS for Server
