Some Arcade functions are not available
4041
04-26-2021 05:29 PM
LanNguyen1
Hi All,
I started playing with the AGOL/Dashboard/Advanced Editing/Arcade and found there are some functions not available for me. Could anyone shade some lights why they are not available?
jcarlson
Check out the Profiles page of the Arcade docs. Certain profiles, like working in Dashboards, don't have access to the same global variables that, say, a popup expression might.
Functions which utilize such global variables will be unavailable in such a case.
With Dashboards in particular, the Arcade is already evaluating against a FeatureSet as defined by the element's selected layer, filter, and sort options. Or if it's a per-feature Indicator, for example, you're actually working with a single Feature object, and not even a FeatureSet. In either case, you won't have access to other layers, or even other attributes within the same layer in some cases.
- Josh Carlson
Kendall County GIS
IhabHassan
I have posted something similar yesterday, I cannot use "FeatureSetByRelationshipName" for no apparent reason. The Arcade expression fails while testing popup configuration expression.
https://community.esri.com/t5/developers-questions/featuresetbyrelationshipname-arcade-function/m-p/...
Regards
Ihab
DarrylAlbert
I am having this problem on a hosted feature layer.  Any idea why that may be?
JEngvall
Did you find a solution/ answer to this?
Ryan_Gould
I had the same issue. I was trying to use a list element with advanced formatting to calculate some statistics. I got it to work by creating a data expression and adding this as a layer in the element.
