select the traced elements
4565
02-06-2015 12:18 AM
MariaMaldini
I am developing a Add-ins button that do a upstream trace in a network , it works correctly without any error but it does not highlight the traced elements.
I do not know how to highlight the traced elements? thanks in advance
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Editor;
using ESRI.ArcGIS.EditorExt;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.Geometry;
using System.Windows.Forms;
using ESRI.ArcGIS.NetworkAnalysis;
namespace testNet
    public class testNet : ESRI.ArcGIS.Desktop.AddIns.Button
        private IUtilityNetworkAnalysisExt m_utilNetExt;
        public testNet()
            UID uidUtilNet = new UIDClass();
            uidUtilNet.Value = "esriEditorExt.UtilityNetworkAnalysisExt";
            m_utilNetExt = ArcMap.Application.FindExtensionByCLSID(uidUtilNet) as IUtilityNetworkAnalysisExt;
        protected override void OnClick()
             try
            INetworkAnalysisExt nax = m_utilNetExt as INetworkAnalysisExt;
                 ITraceTasks pTraceTasks = nax as  ITraceTasks;
                 INetwork net = nax.CurrentNetwork.Network;
                 ITraceFlowSolverGEN tfs = new TraceFlowSolverClass() as ITraceFlowSolverGEN;
                 INetSolver netSolver = tfs as INetSolver;
                 netSolver.SourceNetwork = net;
                 INetworkAnalysisExtBarriers naxBarriers = m_utilNetExt as INetworkAnalysisExtBarriers;
                 INetElementBarriers juncElemBarriers, edgeElemBarriers;
                 naxBarriers.CreateElementBarriers(out juncElemBarriers, out edgeElemBarriers);
                 ISelectionSetBarriers selSetBarriers;
                 naxBarriers.CreateSelectionBarriers(out selSetBarriers);
                 netSolver.set_ElementBarriers(esriElementType.esriETJunction, juncElemBarriers);
                 netSolver.set_ElementBarriers(esriElementType.esriETEdge, edgeElemBarriers);
                 netSolver.SelectionSetBarriers = selSetBarriers;
                 INetworkAnalysisExtFlags naxFlags = m_utilNetExt as INetworkAnalysisExtFlags;
                 int edgeFlagCount = naxFlags.EdgeFlagCount;
                 if (edgeFlagCount > 0)
                     IEdgeFlag[] edgeFlags = new IEdgeFlag[edgeFlagCount];
                     for (int i = 0; i < edgeFlagCount; i++)
                         IEdgeFlagDisplay edgeFlagDisplay = naxFlags.get_EdgeFlag(i);
                         IFlagDisplay flagDisplay = edgeFlagDisplay as IFlagDisplay;
                         IEdgeFlag edgeFlag = new EdgeFlagClass();
                         edgeFlag.Position = Convert.ToSingle(edgeFlagDisplay.Percentage);
                         INetFlag netFlag = edgeFlag as INetFlag;
                         netFlag.UserClassID = flagDisplay.FeatureClassID;
                         netFlag.UserID = flagDisplay.FID;
                         netFlag.UserSubID = flagDisplay.SubID;
                         edgeFlags = edgeFlag;
                     tfs.PutEdgeOrigins(ref edgeFlags);
                 ITraceTasks traceTasks = m_utilNetExt as ITraceTasks;
                 tfs.TraceIndeterminateFlow = traceTasks.TraceIndeterminateFlow;
                 IEnumNetEID resultJuncs, resultEdges;
                 esriFlowElements flowElements = traceTasks.TraceFlowElements;
                 if (traceTasks.TraceEnds)
                     tfs.FindFlowEndElements(esriFlowMethod.esriFMUpstream, flowElements, out resultJuncs, out resultEdges);
                 else
                     tfs.FindFlowElements(esriFlowMethod.esriFMUpstream, flowElements, out resultJuncs, out resultEdges);
             catch (System.Exception excep)
                 MessageBox.Show(excep.Message);
         protected override void OnUpdate()
SpencerHan1
Hi Maria MariaMaldini, I know it's probably outdated. But did you come up with a solution to this issue?
I'm working on something similar to your previous work. And ran into exactly same problem.
Spencer
