Return the bearing of a polygon edge based on selection using Arcade
2325
6
09-13-2021 11:00 AM
Jake_S
by Esri Contributor
Greetings folks,
Looking to be able to return the bearing of the side of a polygon based on a interaction.
I have a carto points feature class that I want to populate its F_ANGLE field with the bearing of the side in which intersects with a polygon. We use that bearing to change the symbology rotation. Any help would be great.
The image below shows a polygon and a point with symblogy interacting. I'd like to get the bearing of that intersection
I have got this working for an intersection of a line feature but not a polygon (image below).
Code for the intersection of lines is below, replacing the feature with a polygon does not work. Looking for someone with a bit more coding knowledge for some help
var LinesFC = Intersects(FeatureSetByName($datastore, "Lines", ['objectid', ''], false), $feature)
if (Count(LinesFC) > 0) {
    var line = first(LinesFC)
    var geom = Geometry(line)
    var pt0 = geom.paths[0][0]
    var brg = Bearing(pt0, Geometry($feature))
    if (brg > 90 && brg <= 360) {
        return (450 - brg)
    return (90 - brg)
return null
Thanks in advanced.
-JS
JohannesLindner
var PolyFC =Intersects(FeatureSetByName($datastore, "gewaesserkataster_sde.GWK_SDE_ADMIN.poly"), $feature)
// return early if no intersecting polygon is found
// doing it this way saves you from indenting everything in your if block
if(PolyFC == null || Count(PolyFC) == 0) {
  return null
// lines have the "paths" attribute, for polygons that's "rings"
var poly = First(PolyFC)
var geom = Geometry(poly)
var pt0 = geom.rings[0][0]
  return (450 - brg)
return (90 - brg)
// if that works for you, cool.
// I got really inconsistent results when testing this on irregular polygons, though,
// so I'd go with something like this:
var vertices = Geometry(poly).rings[0]
var sr = Geometry(poly).spatialReference
// loop through the vertices
for(var r=0; r<Count(vertices)-1; r++) {
  // create a line segment between 2 adjacent vertices
  var p0 = vertices[r]
  var p1 = vertices[r+1]
  var line = Polyline({"paths": [[ [p0.x, p0.y], [p1.x, p1.y] ]], "spatialReference": sr})
  // do nothing if $feature doesn't intersect that line segment
  if(Disjoint($feature, line)) {
    continue
  // return the bearing of the line segment
  var brg = Bearing(p0, p1)
    return (450 - brg)
  return (90 - brg)
// if you land here, the feature intersects a polygon, but none of its edges
return null
Have a great day!
Johannes
BillFox
MVP Notable Contributor
Maybe something in this tool set Reporting COGO descriptions
JohannesLindner
  return null
  return (450 - brg)
return (90 - brg)
    continue
    return (450 - brg)
  return (90 - brg)
return null
Have a great day!
Johannes
Jake_S
by Esri Contributor
Thanks for your efforts here!!!!
Unfortunately the solutions you provided an error by the arcade compiler (see below line 3)
I have seen this error before. the solution was to get a count of the initial FeatureSetByName intersection as seen below in line #2. Yet still gets an error with the geometry statement.
Where are you testing this? I am implementing this as as an Attribute rule on a enterprise geodatabase frim ArcGIS Pro 2.6.6. I wonder if there is an difference in environments.
Again you are a gem!
JohannesLindner
Line 1: Try changing the boolean parameter (includeGeometry) to true.
https://developers.arcgis.com/arcade/function-reference/data_functions/#featuresetbyname
Have a great day!
Johannes
Jake_S
by Esri Contributor
Oh man how did I miss that!!! Genius. @JohannesLindner you are my hero! I saw the same issue with inconsistent results with the first code but the second is working as expected!
JohannesLindner
Also, I'm on 2.6.3, Enterprise GDB, so no big differences there.
Have a great day!
Johannes
