Pro equivalent to ArcSDE Java API SeGeometry
791
08-02-2024 12:09 PM
BartPittari
I'm currently in the process of analyzing some migration paths off of some spatial updates my group supports that currently use the Java API SeGeometry tools below.
First question: I'm assuming that these will be fully deprecated by the end of the mature support for ArcMap?
Second question: What is/has taken its place on the Pro side (is it Python, C#, both, neither, something else)?  We use Oracle as our DB (19c currently, but likely to move forward soon).
https://community.esri.com/t5/forums/searchpage/tab/message?q=java+api
jsde_sdk.jarContains the ArcSDE Client, and Geometry Java API class files.
jpe_sdk.jarContains the ArcSDE Projection Engine Java API class files.
concurrent.jarProvides standardized, efficient versions of utility classes commonly encountered in concurrent Java programming.
icu4j_3_2.jarICU4J libraries required for globalization.
  • com.esri.sde.sdk.client provides classes that expose ESRI's ArcSDE server functionality. Applications created with this package can establish a connection to an ArcSDE instance, query a layer, and otherwise communicate with an ArcSDE server.
  • com.esri.sde.sdk.geom contains classes that implement the OGC (Open GIS Consortium) Geometry interfaces.
  • com.esri.sde.sdk.pe provides classes to define coordinate systems and to transform data between different coordinate systems.
Tags (3)
