Potential bug regarding views created in an sde database?
2626
6
05-06-2024 10:33 AM
RPGIS
by MVP Regular Contributor
I am not sure if anyone else has experienced this issue, but I have an issue with one of my attribute rules where my arcade expression validates but cannot be saved.
I am using 10.9.1 for the sde database. I just wanted to know if this is a sde version issue or a general issue. I am still exploring other means to see if I can circumvent the issue or find another potential solution around it.
RPGIS
It turns out that in order for attribute rules to identify any view(s) the view(s) need to be registered with the enterprise sde database.
VinceAngelo
Esri Esteemed Contributor
There are a number of enterprise geodatabase platforms, even if you don't consider the four different flavors of each RDBMS, so your problem statement is missing critical information.
Please specify the exact RDBMS in use (major and minor version, at least), the geodatabase release of the EGDB, the table definition, the exact attribute rule, and the exact Arcade expression in use.
- V
RPGIS
ArcGIS Pro - 3.2+
Enterprise - 10.9.1
Arcade Expression Version - 1.0.0+
var Asset = $feature.assetnum
var Location = $feature.location
var Check = $feature.CheckWorkOrder
var Query = 'location = @Location OR asset = @Asset'
var WO = OrderBy( FeatureSetByName($datastore, "table.MaxWOs"), 'reportdate DESC' )
if ( Boolean( Filter( WO , Query ) ) ){
    WO = Filter( WO , Query )
    Console( First( WO ) )
The view is created using a linked server so I wouldn't be able to post the definition for it here.
RPGIS
Bud
Legendary Contributor
@RPGIS  When you say "registered with the database", do you mean "registered with the geodatabase"?
RPGIS
Yes. It has to be registered with the enterprise sde geodatabase.
Bud
