PageLayout.ReplaceMaps switches order of dataframes
4399
05-29-2015 01:48 AM
JonMorris2
So, I have an ArcMap addin that, when you add a new map, changes the layout of the dataframes. The TOC remains in the same order, and the dataframes have the same sizes and positions, but the maps within them have moved round.
The code is very simple, just create the map, add it, then call ReplaceMaps:
        internal static void AddNewMap(string mapName)
            if (ArcMap.Document == null)
                return;
            //Makes the new map the active focus map too.
            IMaps maps = ArcMap.Document.Maps;
            IMap map = null;
            map = maps.Create();
            maps.Add(map);
            map.Name = mapName + " (" + Utilities.SelectedRecipe.recipe + ")";
            //Set the reference scale for map frame
            double refscale = 0;
            if (Double.TryParse(Utilities.SelectedRecipe.refscale, out refscale))
                map.ReferenceScale = refscale;
            map.SpatialReference = WGS_1984CoordinateSystem;
            ArcMap.Document.PageLayout.ReplaceMaps(maps);
            // focus on new map
            IActiveView pActiveView = ArcMap.Document.ActiveView;
            if (pActiveView is IPageLayout)
                ArcMap.Document.ActiveView.FocusMap = map;
            else
                ArcMap.Document.ActiveView = (IActiveView)map;
            // refresh document
            ArcMap.Document.UpdateContents();
I found this old post about what looks like the same bug; apparently "it is a known bug that they are working on".
Does anyone know any more about this?
Tags (3)
JonMorris2
Update: support got back to me with a bug ID. It's still not fixed, of course.
NIM001018 (Data Frame order does not match the numbers in the Data Frame Order dialog)
