Old School VBA question
2118
06-08-2016 05:56 AM
jaykapalczynski
Honored Contributor
I am referencing an old VBA script to place a rosette tool in my map.
[ArcGIS 9.x] Rose des vents 3D [Archives] - Forum SIG - Systèmes d'Information Géographique et Géoma...
Although I am seeing an error at this line (In red below)
Set pCirArc = pRubberCircle.TrackNew(pMxDoc.ActiveView.ScreenDis play, Nothing) ...can someone help?
Can anyone please help.....or suggest another Rosette Tool....although I have not found one.
Private Sub Rosette_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
Dim pMxApp As IMxApplication
Dim pMxDoc As IMxDocument
Dim pCirArc As ICircularArc
Dim pPoint As IPoint
Dim pRubberCircle As IRubberBand
Set pMxDoc = ThisDocument
Set pMxApp = Application
Set pRubberCircle = New RubberCircle
' Return a new circle from the tracker object using TrackNew
Call DrawRosette(pCirArc.CenterPoint, pCirArc.Radius)
End Sub
FC_Basson
Space in ScreenDisplay?
jaykapalczynski
Honored Contributor
Thanks....that does appear to be an issue.....but I think I Have another issue.....
I cannot get into the Sub to Draw the circle?  I dont think I can use Rosette_Mousedown because I am not seeing the Msgbox "Hello 2".  The "MouseDown" does not see to work
Thougths?
Private Sub Rosette_Click()
MsgBox "Click Center and Drag Radius to Create Compass Rosette", vbOKOnly, "Rosette Tool"
End Sub
MsgBox "Hello 2"
Set pCirArc = pRubberCircle.TrackNew(pMxDoc.ActiveView.ScreenDisplay, Nothing)
End Sub
