ModelBuilder: Open shapefile using parsed filename
7764
10
07-22-2015 12:44 PM
GaryHoffmann
I'm trying to build a model that will iterate through a series of xyz text files, and clip each text file using a similarly named shapefile on a one-to-one basis. So example01.txt has a corresponding polygon shapefile, example01.shp, which will be used to clip it. So I've parsed out the filename, example01, but when I try to use that as the Clip Feature in the Clip tool, the model refuses to start, claiming that %filename%.shp does not exist. What am I missing? Is there a way to do this?
I've already tested a simpler model that will convert the text files to multipoint shapefiles, and that works on its own. But I can't get Arc to recognize that it needs to evaluate the filename variable prior to checking for the existence of the shapefile.
Thanks.
GaryHoffmann
I contacted ESRI Tech Support and they confirmed that variables can't be used as inputs to a process. So you have to use Calculate Value with some python code to generate an intermediary output, which gives you more freedom to parse out particular substrings from a filename, anyway. Working version shown below. Thanks, everyone, for your help.
DarrenWiens2
Full disclosure, I don't use ModelBuilder very often, but this sounds like a job for a precondition.
GaryHoffmann
I've already got a precondition between the parsed filename and the ASCII 3D to Feature Class process.
EDIT: I've also tried making the parsed filename a precondition to the Clip process. Neither worked.
DarrenWiens2
Oh, I think I see. Try using the full path to the shapefile. For example, C:/yourfolder/%FILENAME%.shp
Or, have you set the workspace environment?
GaryHoffmann
Yep, tried that, too. Both using %INPUT_FOLDER% as a variable and just manually entering the path. It's still saying %filename%.shp doesn't exist.
DarrenWiens2
How do you have the Parse Path tool set up? And, is it the Parse Path tool renamed, or a different tool called Parse Filename? I don't have anything called Parse Filename. What is the exact output value of FILENAME?
GaryHoffmann
It's Parse Path, set to Parse Type = NAME. I renamed it because I was playing around with parsing some paths and such. The exact output value should be, e.g. 840_0810 (UTM easting/northing values that were used to create the filenames). So 840_0810.txt should get turned into 840_0810_XYZ.shp (which works correctly in the simpler model I mentioned), which should then get clipped by 840_0810.shp (a polygon shapefile created prevsiously) to create 840_0810_CLIP.shp.
DarrenWiens2
Try adding a second Parse Path tool to the Name variable, set to Path, and named "PATH". Then, change your Clip tool to look for:
%PATH%/%FILENAME%.shp
ChrisDonohue__GISP
A general suggestion - maybe try loading all your shapefiles into a File Geodatabase, then work against that.  I suggest this as you may be running up against a naming limit having to do with not just the filename but the path.  For example, if the combination of the filename and the path gets close to 255 characters, it can bomb out (even though the specs say it should work fine).
General information on Shapefiles
Geoprocessing considerations for shapefile output
Chris Donohue, GISP
GaryHoffmann
I can try that, but my path names are nowhere near 255 characters long.
