Limiting layers on a map
2211
02-26-2016 03:25 PM
NeemaGudur
I am using the FEMA flood base map service located at
public/NFHL (MapServer)
This base map service has many layers. I am interested in layers 3,27 and 28.
I tried limiting the layers using the following code
var imageParameters = new ImageParameters();
imageParameters.layerIds = [3,27,28];
imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
  imageParameters.transparent = false;
var dynamicMapServiceLayer = new EsriArcGISDynamicMapServiceLayer(oneLayer.url,{"ImageParameters": imageParameters});
map.addLayer(dynamicMapServiceLayer);
The request goes out to FEMA as below.
http://hazards.fema.gov/gis/nfhl/rest/services/public/NFHL/MapServer/export?dpi=96&transparent=true&...
The correct request should be as below requesting only the layers needed
Do I need to modify add something to my code snippet in order to request the only the layers that I need/
Any help is appreciated.
Thanks
Neema
KenBuja
MVP Esteemed Contributor
You have the syntax wrong when you construct the dynamic layer. You're using "ImageParameters" when you have to use "imageParameters". Instead of
you have to use this
var dynamicMapServiceLayer = new EsriArcGISDynamicMapServiceLayer(oneLayer.url,{"imageParameters": imageParameters});
